Chat Area => General Discussion Area => Topic started by: Sixstring on 03 April 2010, 10:46:16
Title: The blokes a star.........
Post by: Sixstring on 03 April 2010, 10:46:16
James posted a thread on here asking for a banjo bolt for my miggy...without retelling the story, the job was a night mare. First I found the PO had broken the vacuum tank by the radiator, (might explain a few things....) then James broke the end off of the plastic box on the plenum clean off, then the banjo bolt sheared, just as well I wasn't going anywhere!
Well, I repaired the vacuum tank with superglue, the plastic bit broken off the plenum got drilled out and epoxy'ed and we eventually found a couple of banjo bolts in Cheltenham.
Oh, and for good measure, the HBV was goosed too.
So far.........Cambelt kit, aux belt, aux belt tensioner, HBV, banjo bolts , oil, filter, antifreeze, fuel filter, brake pads front and rear, water pump, exhaust from the cat back.....2 tyres on the front,    My dad always said "if you want hosses, you got to have losses" and he was dead right.
Haven't totted it up yet, but quickly approaching £500.....
James went to Cheltenham to pick the bolts up for me, The blokes a star, can't say a bad word about him, above and beyond.  Thanks Mate.
Just hope it will work now.......... :-[ :-[ :-[
Title: Re: The blokes a star.........
Post by: Seth on 03 April 2010, 10:56:35
Wouldn't have expected anything less from the man! :y
You'll be up and running in no time at all! 8-)
Post by: alunonhisown on 03 April 2010, 11:46:51
I will 2nd that, Top man in his field. (No Sheep Jokes Please) ;D ;D ;D ;D
Post by: SP_3.2 on 03 April 2010, 11:55:25
 :y :y Nice work james well done
Post by: dbug on 03 April 2010, 16:30:42
Take it you don't need coolant bridge bolts, new dowty seals or oil cooler ones 2nd hand now :o
Post by: Marks DTM Calib on 03 April 2010, 21:07:14
Get yourself a seconds hand vac tank....superglue will NOT hold it  :y
Post by: cem_devecioglu on 03 April 2010, 22:13:31
 :y :y for James..
Post by: TheBoy on 03 April 2010, 22:15:37
It may do for a while, but its not strong enough to put up with much. Apparently ;D
Post by: JamesV6CDX on 03 April 2010, 23:48:22
Not only is it superglued - the whole recess is filled with it, and it's gone as hard as nails - so doesn't look like it will break anytime soon...
That said, I agree in the long term, replacing the tank is preferable  :y
Post by: Gaffers on 03 April 2010, 23:55:10
also epoxy on plastic will eventually fail too  :y
Post by: Sixstring on 05 April 2010, 10:45:46
New one arriving weds.............
Oughta last til then!
