Chat Area => General Discussion Area => Topic started by: Davey on 19 August 2006, 19:36:55
I wired up the loom and ECU today and attempted to start the engine on the stand, I've got fuel pressure, the fly by wire throttle works and so do the injectors but there is no spark :(
The coil pack has 6 pins but there is no reference to pin 1 (brown) on the wiring diagram, pin one goes to a brown/green 6 pin connector which also has the +12v supply for the injectors/flyby wire. I can not find any reference to two of the pins on this connector, one is brown and one is brown/green. I am sure these have to go to something for the coil pack to come to life.
Basically I need to work out where pin 1 on the coil pack goes to :(
Helpppppppppp ;D
Cheers!
