Chat Area => General Discussion Area => Topic started by: Nickbat on 23 May 2007, 12:30:12
Title: Full of gloom...and sewerage.
Post by: Nickbat on 23 May 2007, 12:30:12
I live in an end-terrace house with a shared waste run serving 4 properties. The runs collect on my property and then run out under my front garden to the main sewer.
I’ve had a blocked inspection pit in my garden for about a week now, with raw sewage water running across the pavement.
I have insurance for blocked drains and the company has sent engineers out, but they say the blockage is beyond my property under the pavement or road and, as I have shared system, they won’t unblock it and that it will need a CCTV inspection which they will not provide.
 The main sewer runs along the centre of the road. I was advised to get in touch with Thames Water. They said, and here’s the astounding bit, that the pipe between my property and the main sewer is my responsibility (well, technically a shared responsibility between the four houses). This means that, in the worst-case scenario of a collapsed sewer we would have to pay thousands (literally!) for the road to be dug up and the pipe repaired.
So, let me get this right: if traffic travelling along the road (I’m on a school run) causes vibrations which, in turn, causes the feeder pipe to the sewer to collapse, it’s my problem? The answer appears to be “yes”.  :o :o
This is deeply depressing…and totally unjust. And I was only talking to SWMBO about a new Omega last night…well, that’s down the drain now.  :'( :'( :'(
Title: Re: Full of gloom...and sewerage.
Post by: MikeDundee on 23 May 2007, 12:33:49
Does'nt sound quite right, i think you will find that the sewage pipe from or in your garden is your responsibility, but under the pavement / road should be Thames Water surely.
Post by: Auto Addict on 23 May 2007, 12:34:37
Post by: STMO123 on 23 May 2007, 12:37:12
No. You are responsible for the drain until it hits the main sewer. Just as you are responsible for everything your side of an electric/gas meter. :(
Post by: Big Rod on 23 May 2007, 12:41:32
It's a shame, in situations like this no-one wants to accept responsibility!
There's a bridge near here that was suspected to be weakened, and the council and the railway authorities in charge of the railway the bridge traverses deny accountability, so the solution is to put traffic lights on it and only allow traffic one way!!  >:(
Nuggets!!!
Post by: Nickbat on 23 May 2007, 12:42:04
Exactly, or so it would seem. It's my pipe, but I can't even repair it myself as I am not licensed to dig up the public highway. It just does'nt make sense.  :(
Post by: MikeDundee on 23 May 2007, 12:48:21
No folks I have to argue on this point, given that Nickbats sewage is also communal as it serves 3/4 other properties then Nickbat needs to point this out to Thames water as this forms part of an official Act, which Thames water or any water authority will argue unless you poitn it out to them. Likewise, regarding CCTV surveys Thames water would potentialy not allow you to survey there sections of pipework. essentially Nickbat should CCTV survey up to his garden boundary to confirm whether the blockage/breakage is on his side of the boundary if it is then its his responsibility, if it is on the pavement or footpath/road then it is Thames water, as you do not own the road or footpath/pavement and to dig it up you would need to get licences. thames Water do not need licences for this type of repair work as they are statutory services, and it would also be classed as a emergency repair, due to the environmental issue.
Get back to them Nickbat.
Post by: Kevin Wood on 23 May 2007, 13:29:53
... and if there are 4 houses using that section of pipe you are, at worst, jointly responsible for it even if it's under your garden so get your neighbours to pester them too and make sure they're aware that the bill will be divvied into 4 if Thames don't sort it.
Were they not able to unblock it then? Or didn't they even try?
Post by: Nickbat on 23 May 2007, 13:37:39
Mike, they insist that for houses built post-1937, the pipe to the main sewer is my responsibility - even if it is under the road. Furthermore, insurance comapnies won't cover it because they are not getting premiums from all the sharing properties. Think  >:( I'm stuffed.
Post by: Nickbat on 23 May 2007, 13:40:09
They cleared it once and it blocked again the next day. The then tried rodding it and found that they could get the rods wells beyond my property, but could not shift the blockage. So, officially, there is a blockage under the footpath/road, but no-one will CCTV it because they all deny responsibility.
Post by: MikeDundee on 23 May 2007, 13:42:19
Thats the date I was'nt sure of, re; my reference to the Act which only applies to pre-1937 houses obviously, I take it all the houses are privately owned, none council?
Post by: Jimbob on 23 May 2007, 13:46:04
Can you access your house deeds to see the take on it from there?
Post by: TheBoy on 23 May 2007, 13:55:11
I had a friend in a similar situation.  Alas, it does seem to are responsible (you being all the people on the shared section)
Post by: Marks DTM Calib on 23 May 2007, 13:58:05
Its a grey area......
The system you describe is classed as a private sewer (until it reaches the main sewer) as opposed to a lateral drain (i.e. a drain used by one house).
It is indeed your (and your neighbours) responsability until it reaches the main sewer unless the intermedate connection has been adaopted by the local water authority (which is rare).
Your insurance policy should cover your liability for the repair though (not a good policy if it doesn't).
The Government were looking to change this and get the water authorities to adopt all sewers etc.....but given that its the public sector, its bound to take a while (its been 6 years so far!) plus you can all expect anything upto a £10 a year rise on your water charges when it does happen.
Post by: Kevin Wood on 23 May 2007, 14:18:30
Sounds similar to an issue I had. Blockage between last cover on my property and main sewer, shared with my neighbour. Got a bloke out to unblock it, which he did with a set of rods after farting about for an hour failing to get his jetter working.
He went away recommending a CCTV survey, etc. It blocked 2 weeks later, at which point I decided not to mess around with the muppets again, bought a set of rods and cleared it in 10 mins flat. He had left all the rubble he cleared first time under the manhole cover and a chunk of it had fallen back in  >:(
The point is, we just lifted the main sewer in the street and rodded back up to the blockage and it gave way pretty easily. I get the feeling some of these guys like to make work for themselves, so be a little wary of them.
Post by: STMO123 on 23 May 2007, 14:28:18
Its a brown area actually ::)
Post by: Nickbat on 23 May 2007, 14:39:31
The one of the other end of the block is council owned and the council are looking into the situation. Not hopeful, though.
Post by: MikeDundee on 23 May 2007, 14:41:49
You may just be cheaper in the long run to buy some drain rods from local builders merchants and long sleeve rubber gloves, wellies and that and have a go at clearing it yourself, before you start forking out call out fees to drain clear companies
Post by: STMO123 on 23 May 2007, 14:44:16
You can get a 'worm' which fits to the end of the rods and bores its way through. Be careful to turn it in the right direction though, or it will screw off and become a blockage in itself.
Post by: STMO123 on 23 May 2007, 14:45:09
Or hire them
Post by: Kevin Wood on 23 May 2007, 14:52:14
£29.99 at the local Homebase and I was sorted. That would have paid for the muppet to come back and fiddle around in the back of his van for about a nanosecond. Worth a try I'd say, just in case they're making a meal of it to get a few more callouts.
Doubles up as a chimney brush too, if I ever really want to get into SWMBO's good books  :o
Post by: Marks DTM Calib on 23 May 2007, 14:58:58
Cheaper in BandQ
Rod set: http://www.diy.com/diy/jsp/bq/nav/nav.jsp?action=detail&fh_secondid=9271708&fh_location=%2f%2fcatalog01%2fen_GB&fh_search=rods&fh_eds=%c3%9f&fh_refview=search&ts=1179928500789&isSearch=true
or Wickes http://www.wickes.co.uk/invt/420003
Post by: Nickbat on 23 May 2007, 16:21:31
You may just be cheaper in the long run to buy some drain rods from local builders merchants and long sleeve rubber gloves, wellies and that and have a go at clearing it yourself, before you start forking out call out fees to drain clear companies[/quote
I've got four sets of rods which can extend from th e back of my house right out to the middle of the road. I initally tried rodding it myself, but when I found it was an unshiftable blockage under the road I gave up. The last engineer gave up with his heavy duty rods as well. I suspect something major.  :(
Post by: MikeDundee on 23 May 2007, 16:26:29
I had a similar problem E.G., blockage would'nt shift, got the garden hoses out kept rodding it through the drain with the water turned on and that cleared it eventually, worth a try, if that don't work then you'll probably need to get CCTV survey.
Post by: Allenm on 23 May 2007, 16:31:03
I had a similar problem to this, blocked sewer shared by 4 houses, only me and next door had insurance and it was a bit of dog fight over responsibility.
Eventually, the council were called in to clear (they have to, it is a health hazard) and they charged the 4 houses in question,  It was about 6 years ago and my share was about £30.
You should then be able to submit the council's invoice to your insurance company for them to pay.
HTH
Post by: Nickbat on 23 May 2007, 17:25:37
Result! :) :) :)
The council contractors came round. One huge fella gave it plenty of wellie with an industrial gauge rod and after about 15 minutes there was this huge rushing noise which went on for ages as all the system emptied itself into the main sewer.
The didn't ask me to pay as their job was for the council property on the far end of the run. :y
For information, I did check with my house insurance and a blockage outside my property is covered, although I would lose my NCB. Interestingly though, I read through the small print of the separate drains policy I have (through my water company) and found absolutely no mention of a shared  system being excluded from their liability to repair under the highway, so if it blocks up again in the next few days I shall point that out to them and demand a CCTV survey.
Now, back to that new Omega I was thinking about... ;)
Post by: Auto Addict on 23 May 2007, 17:27:19
Result! :) :) :)
 :y :)
Post by: DaveL on 23 May 2007, 18:53:57
Have had a similar problem with my property except the sewerage came into the house as we were expecting guests for Christmas.  :'( :'(
Called out the emergancy water board crew and got the drain rodded. This happened over 4 times over the next 2 weeks. When the rest of the country awoke from the xmas/new year thing i contacted my insurance people. They quoted the post 1937 act to me. i then had the run around between the insurerance and water board. My property was built in 1720 (year not the time). Got all the cctv work carried out, quotes for repair and sent off to insurance. They then came back with it is not our problem. They eventually backed down when i started quoting hotel bills as property was not safe to stay in. They soon caved in and work was done. The insurance then passed the bill onto the water board to be paid.  :yThe obstruction was just on my boundery and turned out to be a tree root.
Keep on at your insurance and contact each of your neighbours to warn them as well. Always a grey area when differant insurances are involved. Enquire to your local enviroment agency/ council and see if the property has had this problem before.
Good luck and sorry this post is so long winded.
Post by: Nickbat on 12 May 2010, 10:21:43
Well, here we are 3 years on and the sewer collapse has become so bad that they can no longer jet it. The Borough have sent round two honey wagons in the last week but the inspection pit in my garden only stays empty for a few hours.
I have just been told by my Local Authority that a contractor has been hired to remedy the problem - which means digging a 3-metre+ deep hole in the road. Deep joy!  ;) ;D
Still, at least I'm not paying.  :y
Post by: Nickbat on 12 May 2010, 10:23:11
Actually i couldn't pay. Methinks it will be expensive.
Post by: Kevin Wood on 12 May 2010, 10:42:28
Oh, yes. Well, the digging is probably relatively cheap, but the red tape will cost a fortune.
Glad it looks like <fingers crossed> a light at the end of the tunnel (instead of a blockage) ::).
