Chat Area => General Discussion Area => Topic started by: Markie on 17 April 2007, 12:52:03
Title: Individual female torx sockets
Post by: Markie on 17 April 2007, 12:52:03
Does anyone know if Halfords or similar sell individual torx sockets. I know they sell individual sockets  :-/
Sat at work here - after a trip to vx before i started to get water pump and thermostat bolts - and i have just realised i lost my e10 at the weekend  >:(
Machine mart want me to buy a whole set - not a chance Mr Mart ! and theres no time to get an individual one from ebay as i am off from Thursday to get it completed.
I cant use a spanner or similar as i need to torque the bolts....
Title: Re: Individual female torx sockets
Post by: Marks DTM Calib on 17 April 2007, 13:11:21
Yes they do....not cheap though....
Post by: Craig_R on 17 April 2007, 13:17:07
I got my E10 Torx female socket for 3 pounds from a local garage supplier i think they are called Allparts Automotive
I think the female socket was draper or something
Craig
Post by: Markie on 17 April 2007, 14:08:06
nothing ever is in there but needs must  :( cheaper than buying a whole new set from 'mart  :-/
Post by: hotel21 on 17 April 2007, 14:09:05
pm pending....
Post by: hotel21 on 17 April 2007, 15:26:31
Job done....
Post by: Markie on 17 April 2007, 15:42:31
Big thanks to Hotel21 here folks.....the forum strikes again  :)
Broocie has just solved all my short term issues by taking the time out to wrap, address go out to the post office and post first class the socket i so desire.
Ii owe you one Broocie  :y
Post by: JamesV6CDX on 17 April 2007, 16:08:47
Good man Broccie :y
Markie, sockets are £3.50 each from halfrauds... they do individual torx...
Post by: Markie on 17 April 2007, 16:15:19
Good man Broccie :y
had wife check after M DTM said they did them albeit expensive - local one didnt have any - but it is small  :-/ Thanks for the heads up - will try a bigger branch  :y
Post by: sounds2k on 17 April 2007, 22:12:34
dunno if it's the same elsewhere but my local Halfrauds sell individual torx sockets ... well some ... sadly not including the one I have missing!! (E11) ... they do E8, 10, 12 etc. though  :'()
Post by: jonny2112 on 17 April 2007, 23:45:40
My set only goes up to E18 and I need an E20 for the crank! Halfords don't do any larger than 16 iirc but have sourced a single socket (rather than another set) at a local factors. Going for it tomoorrow, but it is expensive at £4.50, although it is quite large and probably not too common.
Post by: Markjay on 18 April 2007, 10:58:50
You should always use the right tools for the job, but if you do get into a tight spot then I found that you can use standard 12-point sockets on Torx bolts.
I would only do that if the bolt is reasonably small and the torque is not too high, and ensure there is a good fit.
This is how I tightened all the 8NM bolts on the cam covers and throttle body – due to bad planning and lack of foresight, my Torx socket set is 3/8” drive while the 5-25NM torque wrench is 1/4” drive…
Now go on, cast the first stone…  ;D
Post by: Markjay on 18 April 2007, 11:00:46
..and Well Done to Hotel21 for his help!  :y
Post by: TheBoy on 18 April 2007, 20:54:28
Wouldn't fancy turning crank over without the proper torx!
Post by: Markjay on 18 April 2007, 23:19:02
Ah, that's where the locking pliers come in handy!  ;D
Post by: Markjay on 18 April 2007, 23:19:56
Markjay crank turning tool:
(http://img252.imageshack.us/img252/5913/19483ep3.jpg) (http://imageshack.us)
Post by: Markjay on 18 April 2007, 23:20:35
OK, just kidding...  :-[
