Chat Area => General Discussion Area => Topic started by: bertiecbx550 on 30 June 2010, 22:33:47
Title: Lap top question...
Post by: bertiecbx550 on 30 June 2010, 22:33:47
Can you charge a laptop via your cig lighter in an omega??? and where would i get 1 if you can please....Only i`m watching over a marquee in Bham at a priests college and the laptop will be the only thing to stop us goin mad.... :D
Title: Re: Lap top question...
Post by: tunnie on 30 June 2010, 22:38:30
no, you need a 240v inverter, best take a feed direct from the battery to the inverter. and put a fuse on it.
Something like this:
http://www.maplin.co.uk/module.aspx?TabID=1&criteria=usb&ModuleNo=224796&C=SO&U=Strat15
Post by: CaptainZok on 30 June 2010, 22:45:52
Things like this must be a figment of my imagination then.
http://shop.ebay.co.uk/?_from=R40&_trksid=p3907.m570.l1311&_nkw=laptop+car+charger&_sacat=See-All-Categories
Post by: Mr Skrunts on 30 June 2010, 23:00:53
 I have a 300watt invertor from maplins, cost me £19.99, only used it once with a P4 sony vaio from rotherham to wigam and back when I went to pick my diplomat wheels up.
Superb unit, would recomend one.   :y
Post by: tunnie on 30 June 2010, 23:01:09
Tried those, don't work very well. Much more reliable having a direct feed  :y
Post by: CaptainZok on 30 June 2010, 23:04:35
Never had a problem with mine, does the direct feed have to be gaffer taped externally to cool the wiring??
Post by: tunnie on 30 June 2010, 23:15:48
Could have been the Senny's ciggy lighter but it was very flaky. I was running a very beefy laptop though, direct feed though with gaffer tape no issues  ;D
Post by: zvi on 01 July 2010, 00:15:19
they are ok but try only to charge when laptop is off
Post by: Kevin Wood on 01 July 2010, 00:18:38
No problem running a small inverter from a ciggy lighter. Laptops only need 40 or 50 watts at the absolute most.
Post by: PhilRich on 01 July 2010, 13:12:20
The 'Universal' ones are fine, as long as there is an adaptor pin that fits your lappy ( the one I bought didn't fit my Compaq Presario). I use it for powering the in-car DVD player for the grandkids now. I have a 12v to 240v inverter that plugs into the rear seat power point for the lappy now (the plug wont fit the front one for some reason  :o) & it has built in fuse & USB plug, cost £10 from the bay. :y
Post by: Marks DTM Calib on 01 July 2010, 15:21:30
Dont forget the fuse...  ;D ;D ;D :y.....and the wire itself does not count as a fuse  [smiley=tongue.gif]
Post by: tunnie on 01 July 2010, 15:54:25
Gaffer tape is an excellent fuse  ::) - Also handy weather protection  :P
