Chat Area => General Discussion Area => Topic started by: Mr Skrunts on 09 July 2010, 19:00:12
Function
Single System DTC Read
All Systems DTC Read
SRS/Airbag reset
MID reprogram
NCDC Code discovery option below
GID/CID pair/depair
Climate Control reprogram
Cruise Enable
Gearbox Update Facelift only
Single Key Program
Multiple Key Program
Gearbox/Climate updates & All Systems DTC check/reset
Gearbox/Climate updates,cruise enable & All Systems DTC check/reset
Keep hearing different things that Tech 2 does, like a sweep up and down on the headlights to clean the guides.
There was also something (tunnie maybe) that was meantioned and could be tweaked that sounded interesting. (sadly cant remember what it was)
Whats involved in the whole systems highlighted above.
TIA :y
Headlight sweep possible on Xenons, had mine done by MDTM a whiie back
headlights yes, it can be used to control the motors and adjust the lights fully down and up, good way to see if you got a lady light :)
Mind on other things Tunns?
*lazy light even! D'oh!
It's ok, Schumaker. :y
Might be this I couldnt remember, I think my headlights are far too low and cars coming up behind me seem to light the road up further than my car does.
Mainly cause Omega headlights are rubbish!
Single headlight on my bike is better than car!
adjust them up then :-/ whether auto or manual adjust, there's still a point you can adjust your headlights to, that the auto or manual adjusters return to.
Am assuming the normal point is where with the lights on and the car empty on level ground.
yes. ;) use a wall or garage door :y
With autolevelling headlights, the correct way to adjust is still via the manual adjusters. Tech2 cannot adjust height (not strictly true)
The correct way is to tech2 to reset counters, manually adjust, exercise and reset counters again, then check again.
Please excuse what may seem a daft question with a very simple answer.
What does DTC Read mean
Diagnostic Trouble Code :y
Said it would be a simple answer, cheers JB. :y
