Chat Area => General Discussion Area => Topic started by: alzoe on 09 July 2010, 23:34:38
Title: ELITE PETE
Post by: alzoe on 09 July 2010, 23:34:38
Just a huge thank you to pete for sorting my very poorly mv6 out.Above and beyond the call of duty imo.cambelt, rad, abs ecu,water pump,breathers &stat.Rocker Gaskets. flushed matrix and a service!!!Oh new plugs, injectors and leads PHEW!!
All this for peanuts considering the work you did m8.
Thanks Again (car is running wonderfully now)
Kind Regards alan :)
Title: Re: ELITE PETE
Post by: albitz on 09 July 2010, 23:40:18
Sounds like hes getting the hang of it. :y :D ;D
Post by: The Red Baron on 10 July 2010, 00:06:43
well done pete. :y
Post by: webby23 on 10 July 2010, 07:28:28
A credit to OOF Pete.......well done mate
Post by: Dishevelled Den on 10 July 2010, 08:56:27
Top work Pete 8-) 8-) :y
Post by: markspark on 10 July 2010, 13:16:08
nice one pete credit to you
Post by: des.allen on 10 July 2010, 13:31:36
It was the same when he has done work on my car, always does an A1 job and will bend over backwards to help (cue comments ::) ) :y
Post by: Elite Pete on 11 July 2010, 14:58:56
Cheers Alan :y
Glad its running better :y
Post by: Mysteryman on 11 July 2010, 18:46:08
Cheers Alan :y
It should be Pete ;D
Post by: Chimpchoker on 13 July 2010, 11:58:56
So why the blinkin eck does he live down souf and not in the NE???
Comments not really needed.....
Post by: Debs. on 13 July 2010, 12:05:47
....and that the CPS aren`t persuing the prosecution for the last work he did! ;D
Post by: Elite Pete on 13 July 2010, 15:03:44
:o :o
Thanks Debs, that should put the end to any other jobs i'm likely to get ;D
Post by: Pitchfork on 13 July 2010, 18:05:43
Since when has Northwich been South?
Try coming from Hamble - that's so far south that any further & you get your feet wet unless you can jump to the Isle of Wight ;D
