Chat Area => General Discussion Area => Topic started by: Martin_1962 on 02 May 2007, 21:03:58
Title: Make sure your handbrake works!
Post by: Martin_1962 on 02 May 2007, 21:03:58
Today I heard Brian outside shouting Martin Martin, so looked out and my car had moved!
The ginge had leant against my car and it rolled slowly down the slope into our office sliding doors :o (Industrial units and we have the upstairs)
Ran out and got in - car would not start - some plonker (me) had not pushed through to Park and the hand brake didn't grip too well.
Everyone said I forgot the hand brake. I said I forgot to Park and that Omega hand brakes are best of a bad bunch - for real brakes better than drums and better than calipers with silly rods in them.
Title: Re: Make sure your handbrake works!
Post by: TheBoy on 02 May 2007, 21:05:37
I suspect you will be adjusting it properly then...
Post by: theolodian on 02 May 2007, 21:06:49
Adjusting doesn't necessarily make it work.  Mine works no better, just doesn't come to the top.
Post by: Martin_1962 on 02 May 2007, 21:07:14
NExt year new shoes and discs
Post by: TheBoy on 02 May 2007, 21:10:12
Why? Not often these wear out.  More likely just need cleaning up a bit and readjusting...
Post by: theolodian on 02 May 2007, 21:12:25
Probably won't help.  Mine were new last year.  Still doesn't hold.
Post by: Martin_1962 on 02 May 2007, 21:19:28
Not for the drum bit but the disc bit - hand brake is not good and the discs are pretty worn
Post by: Markie on 02 May 2007, 21:50:50
ouch - any damage to car?
sure theres a how to for adjustment on here  :-/ but its fiddly and mine still isnt perfect either,,,
Post by: theolodian on 02 May 2007, 21:56:32
How to for service but doesn't cover adjustment.
Post by: Markjay on 02 May 2007, 22:08:29
This is no laughing matter - an ambulance crushed a 4-years old child to death recently, it is said to have had both the gear in 'Park' and the hand break on yet it rolled... to all those who said (in another thread) that they don't bother with the hand brake - better safe then sorry.
Post by: Martin_1962 on 02 May 2007, 22:08:37
None - or there would be damage to Brian!
Post by: Martin_1962 on 02 May 2007, 22:09:27
How could that happen?
Post by: Markjay on 02 May 2007, 22:10:37
Also - on facelifts (and Ithink also on mini-facelifts?) you are not suppose to be able to remove the key from the Ignition if the car is not in Park, but this does not work any more on mine - never actually looked into it to check what went wrong...
Post by: TheBoy on 02 May 2007, 22:11:52
IIRC, you can in N...
Post by: Markjay on 02 May 2007, 22:13:03
There were kids playing inside the ambulance, it was on a school demonstration, so it is possible that one of them shifted the gear and released the hand brake, but it is still strange because it is not easy for a toddler to do this... also, they said that an engineer inspected the ambulance and found no mechanical failure, i.er. the Park and hand brake both work, but they didn't say if they found engaged after the incident...
Post by: Martin_1962 on 02 May 2007, 22:16:06
I know - mine was in R not P!!!!!!!!
Post by: Markjay on 02 May 2007, 22:20:27
http://www.dailymail.co.uk/pages/live/articles/news/news.html?in_article_id=450954&in_page_id=1770
Post by: theolodian on 02 May 2007, 22:23:38
A few weeks ago I was so careful setting the handbrake on a hill that I forgot to put it in Park.  Came back and wouldn't start.  Looked down and it was in Drive.  Thankfully it hadn't moved!  Park is 500 times as effective as the handbrake on my car.
Post by: Danny on 02 May 2007, 22:26:31
did the child die then? first reports hadnt said so
Post by: Markjay on 02 May 2007, 23:24:17
It says 'Toddler crushed to death..' so sadly the answer is yes. And he was 2, not 4 as i said before (he was in a group of 2 to 4 years old, I didn't read properly)
Very sad  :(
Post by: Matchless on 02 May 2007, 23:44:21
Strip the rear brakes, deglaze the drum with emery paper, file 6 - 10 mm leading and trailing edges on the shoe friction material. Make sure that the operating levers pivot properly, they can seize up. Refit the drum.
Get underneath and drop one of the exhaust heatshields so you can see the handbrake cable adjuster.....loosen it right off.
Adjust the handbrake shoes through the hole in the drum until they just lock the drum, pull the handbrake lever hard a few times and bang the drum with a wooden mallet or bit of wood to help the shoes to centralise.
Now back off the shoe adjuster slightly untill the drum is free, dont over-do this but dont leave them binding either...the difference is only one notch.
Tighten the cable adjuster so the brakes are locked on the third click.
Replace heatshield etc.
On an auto, if you use the handbrake to control speed on the morning-reverse-off-the-drive then it will keep the shoes and drum face in good condition.
Post by: theolodian on 03 May 2007, 10:35:31
Where were you on Saturday?  ::)
I didn't have to drop any heat shields.
Post by: Markjay on 03 May 2007, 23:46:36
Checked mine - definitely FUBAR - key comes out of ignition barrel in any gear.
Post by: Paul M on 04 May 2007, 12:16:29
I *always* make sure the handbrake is working properly, had to get it adjusted recently but mine works perfectly well and will hold the car on steep hills with a bit of effort. I usually leave it in 1st gear out of habit, and just in case the handbrake fails while parked, but that's more a belt and braces approach -- it's still the handbrake that's actually braking the car to stop it moving (hence the name, funnily enough ;)).
The only time I make an exception is if the car is going to be parked for a few weeks and it's on a flat, in that case I'll leave the handbrake off and just leave it in gear to prevent the handbrake from sticking.
A car with a dodgy handbrake is dangerous IMO, even when mine had too much travel it still worked fine (the lever was almost out the sunroof though lol). Well worth getting it sorted, if it doesn't work properly after adjustment then either the cable or mechanism has probably seized.
Post by: stevief on 04 May 2007, 12:56:20
A "failed" parking brake is the only motoring offence I have had in 30 years and it only rolled far enough for the shoes to engage, inches more than feet. Subsequent attempts could not replicate the movement but I was still charged as the parking brake was supposed to stop the car moving on its own from rest without back up from the gearbox.
I was suspected of misbehaving so was stopped and this was the only way they could charge me although I have heard of cases where unintended take offs such as Martin's have resulted in fines and also insurance company refusal to pay out on damage due to insuficient maintenance.
Maybe some of the Police members can clarify the situation but it is galling when you get done for something that should be easily maintained.
Steve
Post by: Markjay on 04 May 2007, 15:07:02
Steve
If they got you for that then I am assuming that they checked the washer fluid level and tyres pressures but couldn't fail these?   ;D
Post by: stevief on 04 May 2007, 16:39:19
Steve
Almost but not quite. If it had been the driver who pushed the car to initiate the move I would have been okay but it was just my luck to get the co-pilot who obviously scoffed the majority of the free buns procured from the local bakers so no chance :'(.
Steve
