Chat Area => General Discussion Area => Topic started by: feeutfo on 21 November 2010, 10:29:09
Title: Thinking about buying a press
Post by: feeutfo on 21 November 2010, 10:29:09
...perhaps not suprisingly....  ::) ;D
...any pointers? 12 ton? bench mounted or floor standing? Can't see I'll need floor standing and the extra throat depth, but then there's not that much difference in price. Have had need of one on other cars and my bushes need doing on both cars here. So with 240 quids worth of wishbones needed I can buy a press and bushes and still be quids in. :y
 Can buy one on gaybay for less than the price of a pair of wishbones...
Although they all seem to have this delayed delivery date, what's that all that about?
Anyway, thoughts on these...?
http://motors-parts.shop.ebay.co.uk/i.html?_nkw=12+ton+hydraulic+press&_sacat=30928&_odkw=&_osacat=30928&_trksid=p3286.c0.m270.l1313
Title: Re: Thinking about buying a press
Post by: feeutfo on 21 November 2010, 10:34:08
10 ton seem more pricy  :-?
http://motors-parts.shop.ebay.co.uk/i.html?_nkw=10+ton+hydraulic+press&_sacat=30928&_odkw=12+ton+hydraulic+press&_osacat=30928&_trksid=p3286.c0.m270.l1313
Post by: Varche on 21 November 2010, 11:08:50
Not only that but you are nice and centrally located for a postal or personal visit press bush service (ooer missus). You would have the makings of an SME there.
You could buy old cast off wishbones for a few pence, coat of paint and new bushes off the peg.
Name for the enterprise Wishbushes RUS?  ;D
Post by: lee4206 on 21 November 2010, 13:16:37
[/highlight]
I have a similar one to those as well as the 20 ton one and its ok for occasional use but don't expect much. The pin that is below the jack has a tendency to bend/snap off (re-welded mine back on) and they're not the most precision presses .
Lee
Post by: Kevin Wood on 21 November 2010, 14:31:51
Dazzler used something like that to do my bushes and I thought I was going to end up buying him a new one at one point. :o
Groaned a bit but did the job.
Bear in mind you'll need some drifts of exactly the right size.
Post by: tidla on 21 November 2010, 15:41:16
never used one.
i fit commercial vehicle bushes with large hardened allthread.
the more important part is the tool or whatever you use to sit over the bush onto the edge or shell of the bush.
i have a large box with some old pipe dies of various diametre.
as for pressure on the small bushes (sprinter bottom ball joints/rmovano top ball joint) a large vice  (preferably someone elses) and a hammer suffice.
you have a better "feel" when fitting.
workshop fitting the merc balljoints stuck a hole in the roof thru over zealous use of a press!!
Post by: feeutfo on 21 November 2010, 15:54:39
I was wondering about the range when they finally pop out, can it be aimed? Like over a neighbours fence...? ;D
Post by: millwall on 21 November 2010, 16:20:58
only one way to find out  ready   aim    fire ;D ;D
Post by: feeutfo on 21 November 2010, 17:06:56
So be it. Aim to please... ;)
Post by: Mysteryman on 21 November 2010, 17:34:52
Buy a press wot prints money. Then you can buy a proper car. ;D
Post by: feeutfo on 21 November 2010, 17:49:18
Where's the challenge in that? :P
Post by: Andy B on 21 November 2010, 18:17:09
and a ring of some sort to support the other side of the wishbone while the bush is going in or out, they're only pressed steel and easily distort.
Post by: feeutfo on 21 November 2010, 18:21:54
Aaeye.  :y
Post by: Bent valve on 21 November 2010, 18:59:32
A BIG vice will do the job as well as one of those cheap presses, although it helps to have an assistant to hold the spacer and drift in postion while you take up the slack.
I have pressed out many, many suspension bushes with the trusty old vice :y
Post by: tidla on 21 November 2010, 19:22:15
(http://i1045.photobucket.com/albums/b460/tapper888/AirChisel.jpg)
makes removal easy.(not a cheap one though)
Post by: Andy B on 21 November 2010, 20:36:42
Aaeye.  :y
and as said before, I wish I'd kept the drifts etc I made years ago to press my Senator's wishbone bushes out ..... but I didn't  :(
Post by: r1 on 21 November 2010, 21:46:40
[/quote]
isnt that what old sockets are for?
Post by: feeutfo on 21 November 2010, 21:51:20
isnt that what old sockets are for?[/quote]
58mill outside diameter....?
Post by: tidla on 21 November 2010, 22:00:26
old transit hub socket
Post by: cem_devecioglu on 21 November 2010, 22:09:25
 ;D ;D ;D :y
Post by: Andy B on 21 November 2010, 22:12:29
58mill outside diameter....?[/quote]
58mm about 2" 1/4" ..... is that all? I remembered the Senator's being bigger, but I know the Omega's isn't dissimilar so can't be.  :-/
Post by: feeutfo on 21 November 2010, 22:33:06
[/quote]
Front bush def 58 plus a smidge, not sure on the rearward smaller bush...
http://www.omegaowners.com/forum/YaBB.pl?num=1289930039/0#0
Post by: Kevin Wood on 21 November 2010, 22:44:15
Here you go, mate. Machine Mart - always a winner, and bound to be a VAT free day soon.
http://www.machinemart.co.uk/shop/product/details/clarke-fp12b-fruit-press
Just need some apples. I've got the rest of the kit. Mmm. Cider. :P
Post by: feeutfo on 26 November 2010, 17:27:07
Right, had a go on a couple of presses at local garages and it's not so straight forward. First one did not have a floating head! Meaning the side frame is in the way when doing the forward bush. It means holding the wishbone on end and throug the middle of the "parallel bars" on the press, this in turn means the side frame is in the way, unless like the second press used, it has a sliding ram meaning pressing off center to the press to get it all lined up.
So needs to be ten ton with a sliding head, or fixed head with a very wide throat....or a single beam to press on instead of a two parallel beams....? Can just hook the wishbone on the side then.
Post by: Marks DTM Calib on 26 November 2010, 18:41:13
I would say 10 ton is a little light duty
Post by: Jimbob on 27 November 2010, 09:12:04
Mark, did you ever get anywhere with that 'reclaimed press' that was a little on the 'weighty' side?
Post by: feeutfo on 27 November 2010, 09:13:48
Hmmm, maybe. Although this one never went over 8ton according to the gauge. Nout to say the gauge was accurate, but I reckon the hydraulics had a bit more to give, and the bush had peaned over from me belting the edge with a sledge, press still forced the bush in.
Was yours single beam Mark?
Post by: Del Boy on 27 November 2010, 09:20:53
I'd actually be interested in buying one of those presses. The amount of times I've needed one, mind you if I pack in the trading won't be much point  :-/
