Chat Area => General Discussion Area => Topic started by: pscocoa on 29 May 2010, 20:35:41
Title: combi boilers and triton showers
Post by: pscocoa on 29 May 2010, 20:35:41
Silly me - I thought I would have a chill out weekend but then the call comes from my daughter.
Basically the thermostat lock on the heat control valve cover has broken but in any case apparently the water temperature variation has been all over the place for some time - scalding one minute freezing the next.
At my house we are on gravity plus power showers so no problems but can anyone confirm that with a combi boiler and a theromstatic valve you are bound to have problems with water temperature control if someone runs a tap elsewhere and any solutions.
I suspect one of the problems is that as my daughter is in a victorian terrace on a shared supply with two other houses there is an increased problem.
I have had a go at trying to set the temp with a wrench whilst the valve cover is wrecked but it is impossible.
Anything recommended for  showers with combis?
Title: Re: combi boilers and triton showers
Post by: Kevin Wood on 29 May 2010, 20:41:27
As long as the shower valve is thermostatic it should be able to cope. Not ultimately as good as a pumped shower on a gravity fed system but they can be made to work.
One thing you could do is to fit a pressure regulator to the incoming mains to iron out any variations due to external influences.
Has the system previously worked acceptably? If not, do you know what has changed to cause this issue?
Post by: Marks DTM Calib on 29 May 2010, 20:58:05
Whats the hot water output in BTU?
Quite often these poor quality plumbers fit uber cheap combis with low water heating capacity.....
Post by: feeutfo on 29 May 2010, 20:59:03
if this is on the triton i've had 3 go on one of ours, it cant tell the temp so it heats until the cut out resets and so on, 36 sobs from triton(?) web site.
but by the time i'd paid for 3 stats i could have bought a new shower unit  :-/
another resason why we need to fit a combi boiler, massive cold pressure, in our house and break all hot water pressure from the 30 year old plumbing to our gravity shower taps on the bath, rubbish >:(
Post by: pscocoa on 29 May 2010, 21:08:23
The water is really hot - it is getting the comfortable balance that is the problem
Post by: pscocoa on 29 May 2010, 21:12:43
I think it has worked in the past "acceptably" as you say and therefore I am tending to agree with Chrisgixer that the thermostatic valve unit is knackered and no longer able to regulate the temp.
Question is replace it with what?
I suppose short term get another unit which will fit the pipe configuration and give Triton customer service a going over.
Post by: jimbobmccoy on 29 May 2010, 21:19:33
We had a combi boiler and triton power shower at our old place. The pressure wasn't that great, and when it got to the first winter we found that the water would get hot to the point of scalding, then cold then hot and so on. First thing we learnt was an 8.5 kw shower won't be much cop in winter.
After much umming an ahhing and speaking to an old school plumber we decided to fit mixer taps and run straight off the combi boiler. I was dubious as the tap pressure from the hot wasn't that good, but it actually worked really well. Better pressure than the electric and no temp fluctuations.
I was warned against tampering with the incoming mains pressure btw, aparantly very against the law!!( but I prob didn't grasp the point made by kw-I'm no plumber!)
for the more expensive route I was told you can feed a hot water tank from a combi boiler and then go the gravity fed with power shower route.
Post by: jimbobmccoy on 29 May 2010, 21:21:38
Also, tho probably not relevant here, I had similar issues when I moved, and would thoroughly recomend a power shower to anyone with a grvity fed system.
Looks like an electric one on the wall, but way better. :y
Post by: pscocoa on 29 May 2010, 21:29:55
sorry if it was not clear but it is not an electric Triton but a dual valve thermostatic. Some interesting observations - thanks guys.
Post by: jimbobmccoy on 29 May 2010, 21:35:15
Ahh, it's just like school all over again, "young jimbobmccoy must pay more attention".
Your first post did make it clear what shower type it was.
Post by: pscocoa on 29 May 2010, 21:53:58
but your info was great because my daughter is now asking for the electric version - so we need to take a time - out. I have a plumber coming at 10 tomorrow - but can I find a Triton Humber or similar mixer valve on its own on a bank holiday. Ebay has a kit but need to do job asap.
Post by: pedroMV6 on 29 May 2010, 21:57:56
We recently had a Worcester Bosch combi boiler and Mira mixer shower installed (within the last 2 1/2 years) and they're excellent in our house (3 bed, 1930's semi).
Water pressure does affect the shower a little, but never scalding.
Post by: Kevin Wood on 29 May 2010, 22:01:58
I would keep the gravity fed system and pump the hot & cold to a decent shower mixer, personally. :y
Post by: jimbobmccoy on 29 May 2010, 22:03:11
The mixer I was referring to (rather unclearly!) was a set of mixer taps to replace the normal bath ones, the type with the shower hose attachment on the top of them.
I picked a pair up for about £35 and managed to bodge it myself, but beforehand did the following to check the pressure.
I went to Argos and got a cheap (£5-7) shower that you push on over the tap heads of the bath.
Got it to temperature and could see the pressure would be fine.
It was easier to replace the bath taps with the mixer sort than fit a seperate mixer shower (the type that sits mid way up the wall) an cheaper too.
I even used the hose an hose rail from the old electric shower.
In my limited opinion, I woulddo everything possible to find an alternative to am electric shower, as unless it's a very expensive one wit a high powered element they aren't that great.
Post by: Taxi_Driver on 29 May 2010, 23:20:17
Or depends where the header tank is for the hot water cylinder is. In my house, i have a loft above the kitchen....and that was where the header tank was fitted and i had low hot water pressure....i had it moved to the loft above the bedrooms upstairs...hot water pressure fine now  :y So basically, the higher up you can get the header tank the better the pressure  :y
Post by: pscocoa on 30 May 2010, 07:25:33
Managed to find the make of Triton fitted (it was in when she bought the house) and it is the Mimosa which is one of the cheaper units. I will need to try and find out (maybe from Triton) if buying a higher quality unit is going to make this problem signifcantly less. First job today though is try and work out if there is any anomaly in pipe work (i.e. is hot feed going to correct inlet) or whether it is the thermostat cartridge inside the unit which needs replacing - which is a possibility I picked up from googling.
Post by: Danny on 30 May 2010, 10:27:47
i have a combi boiler, and a mixer shower (fitted 2 months ago with a complete new bathroom), i have no trouble at all with the water pressure or temp
could it be the shared supply causing trouble? obviously a tap being used in our house affects the flow, so we both (swmbo and i) know to leave the water alone when the other is in the shower
Post by: Kevin Wood on 30 May 2010, 10:30:55
Another thing to try is to run a hot tap slowly and see if the boiler can supply a consistent temperature or whether it itself is cycling between hot and cold.
A decent combi will have a modulated burner so it can adjust heat output to demand (within reason) but it's possible it's an old one that doesn't, or it is cycling due to a fault.
Post by: pscocoa on 30 May 2010, 20:33:10
Plumber reckons I could buy expensive shower mixer and still have problems.
In circumstances have bought a new shower exactly same as the one installed off ebay for less than buying thermostatic cartridge off Triton - hopefully it is this that has gone. will take a couple of days to get here - in meantime my work with the wrench at least makes it useable with a bit of deft temperature switching when taking a shower.
Thanks for all the advice.
If it still acts up then back to drawing board. One step at a time though.
Post by: Kevin Wood on 31 May 2010, 00:32:12
Problem with plumbers, etc. is that if it's not done "their way" it'll never be right in their eyes whereas there's always more than one way to skin a cat.
Hopefully the replacement will do the job. :y
Post by: pscocoa on 08 June 2010, 23:05:43
From the new shower purchased off ebay, the thermostatic cartridge has been removed and used to replace cartridge in old shower - (saved a lot of hassle in getting whole of old shower out of wall panel). Problem of no control of water temperature  has been cured - result. 5 years warranty on new unit.
Post by: LoveOmega on 13 December 2010, 11:21:35
<Spam removed>
Post by: CaptainZok on 13 December 2010, 11:25:48
I've cooperated with one company only.  :-[ It's Gainsborough Showers. They offer a wide range of products with affordable prices (if you are interested in ). And the most important they have Advice center! :)...Triton, Mira, Aqualisa are good too. But I can't say anything else about those companies.  :-? (http://www.spammingscumbag.com[/url)
What are you having for dinner then, spam sandwiches by any chance? ;D ;D
Post by: Kevin Wood on 13 December 2010, 11:30:37
Guess it'll have to be a take-away, then. :D
Post by: LoveOmega on 13 December 2010, 11:59:34
Why did you decide that this is spam?  :-/
Post by: Kevin Wood on 13 December 2010, 12:38:34
Apologies if it was posted with the best of intentions. It fitted a profile which we generally look out for. New user signs up, and in the first few posts drags up an old thread with clearly identified products in the title and posts a commercial plug without introducing themselves,first, etc.
Clearly that wasn't the case here, as such users normally disappear into the woodwork never to be seen again after a couple of posts. Again, I'm sorry that in this case you've been confused with such an individual but hopefully you can understand how that may have happened?
Welcome to the forum. :y
Post by: LoveOmega on 14 December 2010, 14:38:34
I understood! Thanks!  :y
