Chat Area => General Discussion Area => Topic started by: Kai on 07 January 2011, 19:47:10
Does any one know anything about blackberrys? The a has stopped working on myn and wonderd if any one can or know's away that it can be fixed?
Tia
Kai
Gay goosebury? No idea!
I usually cook those in pastry, and then cover in hot custard :D :D ;)
No, sorry, I am the last person to know about what I take it is a new fangled 21st century electronic do-it-all device! ::) ::) ;)
I suspect a foreign body has got under the keyboard membrane if it's only one key. If you are up to dismantling it then it should be quite easy although I've never done a
raspberryblackberry.
If not, you need to take it to a shop.
how about giving it a blow with an airline
You beat me to it Lizzie. I was going to suggest sugar, single cream & wrapped in a pancake!!!! :D
I suspect a foreign body has got under the keyboard membrane if it's only one key. If you are up to dismantling it then it should be quite easy although I've never done a raspberryblackberry.
What that man said, but the newer BBs are held together by tiny tiny tiny torx screws, so you're going to need some small specialist screwdrivers to get in there, most likely!
Oh and..
[media]http://www.youtube.com/watch?v=kAG39jKi0lI[/media]
i bought my boy one, i cant even press a button as the digits are so small, and its a bit complicated for me as well :(
remove the keyboard and check there is no much and filth in there.
A quick search on google will give you instructions on how to do it
i've had one for a year, actually its my 3rd in a year as the first 2 crashed, quick call and a new ones sent out - i'd call your service, BT mobile have twice just sent me a new one the next day - hopefully you're with them or your provider has the same customer care :y
mmmmmmmmm!! :-* :-* :-* Sounds lovely!! 8-) 8-) 8-) :D
My son spilt white wine over a girlfriends.
I dismantled it, washed the keyboard and contacted with water and alcohol left it in the sun to dey for 10mins, re-assembled and hey presto up and working.
The biggest fiddle was undoing the torx heads as I didn't have anything small enough. I used jewellers screwdrivers as I had a set that had one to allow jaming in the torx head.
I did all this on a sunbed back in August; so no special tools and a modicum of skill.
Hope thi shelps
S
What was that, you want to wrap Lizzie in a pancake and cover her in cream & sugar? :o :o :o ;)
and whats wrong with that ;D ;D ;D
Thanks everyone, although the best thing to do may well have been to put it in the oven, i took it to the local garage and used the tyre inflator on the key pad im sure in the log term thats done it no good but for now it works :) thanks again
Sounds like an ideal job for Sammy Sledgehammer ;D
