Chat Area => General Discussion Area => Topic started by: waspy on 15 January 2011, 19:25:36
Title: Free Ambulance Any One
Post by: waspy on 15 January 2011, 19:25:36
I just got back from the fields with Mutley & on my way up the estate there was an ambulance blocking the road. As i got closer the engine was running & no one was in it, i know there wasn't any one in it, because i could see the paramedics in the front room of a house.
Is this common practice :-/ If so it's a bloody stupid idea :( >:(
Title: Re: Free Ambulance Any One
Post by: Jimbob on 15 January 2011, 19:29:37
often a transponder fitted....may be running, but wont go anywhere without the driver on board  :y
Post by: fudgee on 15 January 2011, 19:31:33
Obviously not common practice but considering the amazing job that paramedics do I'm sure that you can forgive them.
If I saw that I would have gone and told the paramedics before somebody stole the thing or some miserable old Git rang up and reported them... :y
Post by: the alarming man on 15 January 2011, 19:33:11
it is common practise well it was when i worked for the l.a.s...if you was to get in and touch any of the pedals or even open the doors without transponder present it would cut out...need to keep it running as everything on the back is run by battery  :y
Post by: waspy on 15 January 2011, 19:36:39
Well i've learned something new today :y :y
Thank you :)
Post by: Gaffers on 15 January 2011, 19:36:59
What about access to the controlled drugs?
Post by: the alarming man on 15 January 2011, 19:41:22
well they should be locked away but to be honest not that much on a ambulance  :y
Post by: Mysteryman on 15 January 2011, 20:04:47
What exactly do you need Matt?
PM me 8-)
Post by: Lizzie_Zoom on 15 January 2011, 20:06:57
PM me 8-)
Classic! ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D :y
Post by: Sixstring on 16 January 2011, 10:19:42
ACIIIIIIIIIIIIED!!! :D :D :D
Post by: droyboy on 16 January 2011, 10:36:53
The police use a system called run lock, you can remove the keys leaving all lights on etc touch the throttle/brake pedal/hand brake and the car will cut out if some one tries to move it etc
Post by: Sixstring on 16 January 2011, 10:39:36
Avon and Somerset ambulances also have a pressure sensor under the seat, and some also have auto gear select switches, select drive and it dies...........only a hidden switch disables it.
Post by: hotel21 on 16 January 2011, 11:55:12
The runlock system is quite good and can work well.  Release the handbrake or depress the clutch and the engine stops.
Until the Officer with the keys in their pocket goes off somewhere else in another vehicle with them.....   That can be fun   ::)
