Chat Area => General Discussion Area => Topic started by: Terbs on 15 January 2011, 17:37:49
Hi all..
Any ideas on this one !!!!!!!!!
Computer starts to boot up...gets to Windows emblem...then cuts out. >:(
Next try goes to 'Last known config/Safe mode' page.
Have got it started in safe mode....I then shut it down, restarted and it ran perfect. Restarted a few more times ..no problems.
Leave a few hours and it does it again. Once it has booted up it runs fine and dandy. :y
What I have done to try to remedy, is as follows.....fitted new HD (changed from IDE to SATA)...fitted new PSU...removed RAM and swapped around (fitting singly then doubled)....removed PCI-E card and used onboard graphics.
Only thing I have not done is removed CPU and Heatsink....could it be this?
Have reloaded Windows and updated to SP3.
Personally, I think it may have to be a case of strip it all out and start again. :(
sounds like a program on startup causing the issue or a driver
Thanks Plomien.. :y
I never really thought about the drivers..
I have only put Windows Office, AVG Virus Scanner, the MB drivers (usb hub and Ethernet and video) and Nvidia driver for PCI-E graphics in....so I suppose its a wipedown and start afresh, trying after windows initial install, then invidual drivers and programmes. :y
If the Heatsink fan was under load at startup, would that shut the system right down.
BTW, when I say it shuts down, it is a full shutdown (audible click then instant total power off)...not a restart shutdown........ :y
to check the cpu heat strain download speedfan to monitor the temp :y
Given the symptoms, I'd be more inclined to think about an update coming down...
check the system , application events and also bootlogs
Where is this info...in the Bios ?? :)
Start > Run
eventvwr
will get logs
Thanks J :y
also
http://www.watchingthenet.com/how-to-enable-boot-logging-for-fixing-startup-problems-in-windows.html
http://www.windowsreference.com/general/how-to-create-a-bootlog-in-windows-2000xp-and-later/
http://technet.microsoft.com/en-us/library/bb457123.aspx
http://www.vistax64.com/vista-installation-setup/136823-where-vista-keeps-boot-log-if-any.html
http://www.computing.net/answers/windows-95/bootlogtxt/130772.html
Thanks Cem :y
Following all advice given :y
Thanks Cem :y
:y :y
Also check here
www.buyanewcomputeryoutightbastard.com :y
Also check here
;D ;D STMO as usual ;D from where the hell you find that ;D :y
Also check here
I have taken your advice STMO :y
The company just need your address now to send the invoice before I click 'Buy' :y
Also check here
;D ;D STMO , prepare the money ;D :y
Also check here
;D ;D ;D ;D Outstanding ;D :y
SWMBOs laptop suffered the 'black screen of death' about a year ago.
My plan was to recover her personal data and either fix windows or re-install it so I downloaded an Ubuntu recovery disk and left her to sift through the hard disk contents.
After a week of running from the live CD I shrank the windows partition to make space for an Ubuntu install (to allow it to run at a sensible speed).
A year on and Ubuntu is still in use. I never did find out how to fix the windows registry and Ubuntu 'just works'.
Latest update on the computer is that it now boots to the windows flag emblem....then goes no further, just sits there with the emblem and the blue moving line below it. Left it for ten minutes and it still shows the same screen >:( I will try to get it to boot in safe mode, and run the tests you have provided earlier :y
Really baffling me, this one >:(
Stupid I know, but you have tried system restore from Safe mode? eggs grandmas etc...........
Not a stupid question at all, Shackeng.... ;)
That was next in line...however, in safe mode it locks on the page that scrolls down all the drivers...you know the one...Multi (0)Disk(0)RD13K.....Partition(1)\Windows \Sys32\ Drivers\ WMILIB.sys......or very near to that :y Fills the screen then locks. :(
Ahh yes I know the page. Hmm sorry, that's now beyond my pay grade :-? Good luck :y
Last time I had a failure I had to use a rescue disc to extract all my files and then reformat and re-install Windows. It only took about half a day. I can't remember the disc, I borrowed it from a friend, but it works from the pre-boot stage. HTH :y
Not a problem mate.... :y
I have decided to pull it apart, check all connections, in a full rebuild, then reload windows and see what happens :y
I shall then install and run each set of drivers for the motherboard (usb, on board video, ethernet) and see if it runs and do the same for each piece of software I install.
Can't see any other option as it won't boot at all :'(
Other option of purchase gone as STMO123 has gone quiet since I suggested he pays for it ;D ;D ;D ;D ;D ;D ;D
