Chat Area => General Discussion Area => Topic started by: cdx25 on 25 May 2007, 14:41:39
Title: Sweepstake - which bit fails next ?
Post by: cdx25 on 25 May 2007, 14:41:39
Having owned my cdx for (only) 7 or so weeks now I seem to have encountered a few of the more common problems listed on here...
1) Exhausts with stuck cat bolts that needed drilling...
2) Cam cover gaskets and breather valve clearout
3) Front wishbones
4) And most recently the heater bypass valve...
In fairness, I knew about 1) to 3) when I bought it, the other 4) was a sneak up...
So, any guesses to whats next ?  ;D
Jon
Title: Re: Sweepstake - which bit fails next ?
Post by: Marks DTM Calib on 25 May 2007, 14:42:52
Probably Pilot failure.....
Post by: STMO123 on 25 May 2007, 14:45:10
Oil cooler ::) Thats got to be next on mine
Post by: Elite Pete on 25 May 2007, 14:46:48
Steering idler :-/
Post by: ians on 25 May 2007, 14:51:12
Door bushes..
Nice easy one for a change :y
Post by: Marks DTM Calib on 25 May 2007, 14:54:42
Only following poor maintenance i.e. wrong mix of antifreeze or in-correct change intervals.
Post by: STMO123 on 25 May 2007, 15:01:40
That's OK then, mine will be fine :D
Post by: Markie on 25 May 2007, 15:09:19
...door not opening...or the crack of doom  :o
Post by: STMO123 on 25 May 2007, 15:12:23
That reminds me, better get some housework done. SWMBO will be in soon.
Post by: AndersH on 25 May 2007, 15:15:58
Got to be crank sensor?
Post by: Markie on 25 May 2007, 15:25:03
 ;D ;D ;D ;D
Post by: hol666 on 25 May 2007, 15:31:06
 :o without being a doommonger, get your cambelts and tensioners changed asap, first thing I did when I got mine!  :'(
Post by: supermop on 25 May 2007, 16:19:15
rocker covers and gaskets
Post by: nixoro on 25 May 2007, 17:51:25
A tyre blow out maybe  :-/
Post by: cdx25 on 25 May 2007, 17:54:16
Cant believe I left that off the list - already done that one too!!!
Post by: cdx25 on 25 May 2007, 18:02:36
Door bushes..
Memory is going, Ive done that one too  :(
Post by: Baron Von Spongebob on 25 May 2007, 18:04:10
The wallet.. :-/ :'(
