Chat Area => General Discussion Area => Topic started by: Nickbat on 27 June 2011, 11:29:01
It's only 27.1c here in London, yet the heat causes cancellations!!! What the....?
http://www.bbc.co.uk/news/uk-england-13926651
:o ::) ::) ::) ::) ::) ::) ::) ::) ::)
Just another "excuse" to say we need upgrades, then shaft us with even higher fares for an already awful service! >:(
So now they are adding heat to the other fails,leaves,snow and water (dawlish warren stops the virgin trains when the track floods with tide) >:( :(
Not uncommon on the older OLE setups.
The result is reduced tension in the cables when they expand a lot in the hotter weather (remember also that the older cables will already have stretched quite a bit once they are end of life) meaning the tension weights may be at their max limit (i.e. full drop).
So, you just slow the trains down a bit to avoid the risk of pulling down the HT wires.
I notice this section is currently having the cables replaced as part of a periodic maintenance program (as they dont last forever!).
So, a no news story really.
Mark 1s just used to get a sea water wash
They need to take a leaf out of this fellas book (pardon the pun):
[media]http://www.youtube.com/watch?v=UzGwUhIXLDk[/media]
Diesels are fine, couple of years ago in the 'big' snow, all other operators had issues, but Chilterns slow little diesels chugged through :y
Bloody hell.chappie in the dayglow suit standing by the gates got a little moist :D :D ;D
Lol, yes, seen that before!
Major risk of de-railment, traction motor flash overs and resultant main gen failure!
Not a good idea on 2 million quid plus locos!
Dawlish has been closed during heavy seas since the day it was built due to the high risk of the line being washed out.
Leaves can be an issues, in bygine years track sides were cleared to avoid fires and heavy locos with high axle loads squishe the pukp out the way.
Modern lighter trains and lack of tree removal means they are a big and very real issue.
and to that newer disc brake systems, even worse. Older style systems would clean the wheel as it braked.
