Chat Area => General Discussion Area => Topic started by: tunnie on 20 August 2011, 19:31:02
Title: IBM Blades
Post by: tunnie on 20 August 2011, 19:31:02
How easy is it to replace hard disk on one? The fool with root access The highly competition techy might be asked to replace one!
Never touched blade servers before.... don't even know how to remove them from the Centre  :-[
Title: Re: IBM Blades
Post by: aaronjb on 20 August 2011, 19:47:26
No different to a regular server, at least it wasn't in the blade server we had in the lab at work. Shut the blade down, release it (just like you'd release a drive in a storage array) and slide it out.
From then on it's just a regular PC in a very small case..
Post by: Taxi_Driver on 20 August 2011, 19:47:50
Are you planning on taking it away with you then  ;D
Seriously, being IBM, i would hope they are easy accessible, hot swappable drives.
So......just unplug the caddy of the drive you want to replace and plug the new caddy(with new drive)  in.
Worth checking with some one else first, but in my IT days years ago......if the disk array was hardware raid....it was pull the old drive out and plug the new one in, and pray it didnt crash  ;D and then went on to rebuild itself  :y
Post by: TheBoy on 20 August 2011, 19:49:45
No changed one on an IGM blade (we have hardware peeps for such simple tasks, people who do get off their backsides ;D)
Proliant blades and Sun blades are simple, hot swap units, same as their standalone servers of same era, can't imagine IBM would be any different...
Post by: Plomien on 20 August 2011, 19:50:14
not sure its the right model but looks fairly straight forward http://h20000.www2.hp.com/bc/docs/support/SupportManual/c00718745/c00718745.pdf
Post by: TheBoy on 20 August 2011, 19:50:58
Shouldn't need to shut it down. Being a blade, it'll be Enterprise class, thus 99% likely hot swap.
Post by: aaronjb on 20 August 2011, 19:53:08
Hm.. our blades were obviously different, then :) You couldn't get at the drives without taking the casing off the blade - and since the blade is the entire server.. I can't imagine Windows would have been too happy with the power being unceremoniously removed as the blade was yanked out :D
Post by: TheBoy on 20 August 2011, 19:54:57
What make? Never seen one without hot swap disks...
Post by: tunnie on 20 August 2011, 19:56:49
I was assuming it needed to be removed in order to replace HD  :-[
Regarding RAID, i've no idea what the setup is. The genius company I used to work for, decided to sack everyone who knew anything about the systems we ran.
Its now down to 5 people (from 60 at its peak) - I'm the only technical member of staff, so not a good start  ;D
I might need to see if they have left any manuals around! Did a hot swappable PSU for first time few weeks back.
Post by: tunnie on 20 August 2011, 19:57:37
Well these blades are running Red Hat, but as the whole service is fubared, the blade can be shutdown  :)
Post by: TheBoy on 20 August 2011, 19:58:34
Actually, I bet Windows would cope far better than most other server systems :P
Post by: cem_devecioglu on 20 August 2011, 19:58:39
server, without a hot swap disk :-?
Post by: TheBoy on 20 August 2011, 20:00:10
Built properly, a failed HDD shouldn't affect service on a server, unless they are using software mirroring....
Post by: TheBoy on 20 August 2011, 20:00:49
OOF's isn't ::)
Post by: cem_devecioglu on 20 August 2011, 20:02:57
OOF's isn't ::)
members , must put the hands in the pocket me thinks ;D :y
Post by: TheBoy on 20 August 2011, 20:08:29
OOF's isn't ::)
For our needs, a 30min outage to replace a disk isn't that important.
Besides, as the server hardware comes out of my pocket, I was the one making the choice between hot plug disks, or some new tyres on the Rover ;D ;D
Post by: tunnie on 20 August 2011, 20:12:38
It all went to poo when they ditched their hosting at rackspace to save money, services where brought in house and everything screwed up!
We are amazed its lasted as long as it has, I cannot get a Sybase Database to boot, it keeps corrupting chucks of the DB, the just disappear from the file system  :-?
At first it was just one, now 6 chucks have gone! Just not listed there....  :-/
We got it all back, i left it alone, came back later in day and the database had died again, booting it again chucks had disappeared!  :-/
Post by: cem_devecioglu on 20 August 2011, 20:13:44
OOF's isn't ::)
 ;D ;D I can guess the choice ;D :y
Post by: TheBoy on 20 August 2011, 20:16:32
OOF's isn't ::)
Given that Mrs TB cooks my dinner, and you lot don't, tyres for her car were always going to win ;D
Post by: cem_devecioglu on 20 August 2011, 20:18:09
normally , the database will be marked suspect in case of some problems.. :-/
Post by: TheBoy on 20 August 2011, 20:19:19
Was fsck running when it came back up?
Post by: cem_devecioglu on 20 August 2011, 20:22:46
OOF's isn't ::)
thats sure.. my stomach is also the #1 ;D :y
Post by: tunnie on 20 August 2011, 20:35:59
Yes, after I rebooted the box i did:
Login as root
umount sda1,umount sdb1, umount sdc1
e2fsck sda1, e2fsck sdb1, e2fsck sdc1
mount –a
Login as Sybase & attempt to start, gets stuck at master device size  :(
Post by: aaronjb on 20 August 2011, 20:47:02
I .. can't remember :) I think they were HP, but I could be wrong - since I changed roles my access card doesn't even let me into the lab where the fun stuff is anymore  :'(
Post by: cem_devecioglu on 20 August 2011, 21:16:02
Login as root
mount –a
did you get any error messages on fsck ?
didi you mount all volumes adressed in sybase ?
otherwise must start normally :-/
Post by: TheBoy on 20 August 2011, 21:36:33
Login as root
mount –a
Did you need to run fsck?  Was the database loaded before unmounting?
Post by: TheBoy on 20 August 2011, 21:38:45
Can't think of an HP blade that doesn't have a SMART Array and hot plug disks.  But then I only really get involved with HP Proliants, not idea if they do Integrity based Blades...
Post by: tunnie on 20 August 2011, 22:04:01
Login as root
mount –a
Those are the instructions I have, no the database was not loaded....
