		Chat Area => General Discussion Area => Topic started by: tigers_gonads on 19 August 2011, 21:32:25
				I'm in the sh*t  :'(
 Back in the days when I had a Td Omega, I used to run it on a mixture of refined chip fat and diesel during the summer with great results  :y
 Right the problem is ........... Sat on top of my shed roof was 3 x 20 ltr plastic containers full of the stufff which I never got round to getting rid of   ::)
 Sometime in the last week ( while I was on holiday ),  some little tw*t has been playing with his air rifle and shot the containers full of holes  >:(
 Now I have around 60 ltrs of chip fat that has been washed by the rain, down the drain pipe and into the drain at the back of the house  :'(
 It has not reached the main part of the drainage system yet because all the sinks in the house drain away without a problem.
 But at the shed end of the system, it is completly blocked up to the point that the fat has totally bunged up the sink next to the drain pipe  :'(
 Ive had my hand in there and been scooping as much fat out as possible but I need to clear the rest of it out before it bungs up the rest of the system or the council and neighbours will be ripping my gonads off  :'( :'(
 Anybody out in OOF land do this for a living ?
 Ideas please
				Caustic soda mixed in mega hot water will dissolve it, wear eye protection though because with hot water its pretty evil stuff.
 Noted  :y
 Any idea where I can get my hands on some ?
				As Mark says .. but be VERY careful ... try and pierce a hole through the gunge with a long thin wire so the caustic has somewhere to drain. Caustic and skin/eyes DOES NOT MIX so protective goggles, strong rubber gloves, old thick clothing (as I doubt you have a leather apron handy) are a must.
 Strong solution with very hot but NOT boiling water added in small quantities will shift it. Once it is FULLY clear run loads and loads of water from a hose down the pipe to ensure you "move" the gunge a long way from your place and to dilute the caustic .. it has a tendency to "eat" the mortar in the drains if left to stand undiluted ... :(
				Any supermarket, even wilkos sell it.
				Thank you  :)
 I'll give it a go tomorrow  :y
				Plasic bucket ok to mix it in ?
				Yes, its fine with plastics.
				Ow, watch out for anything with chrome plating.....it removes the plating....plus paint as well!
				Ow, watch out for anything with chrome plating.........
 or ally  ;) ;) ;)
 Caustic + ally = horrible fumes
				B&Q have it as well :y
				I feel a great disturbance in the Force, as if millions of deep friers suddenly cried out in terror, and were suddenly silenced.
				Caustic Soda worked a treat  :y
 Thanks all  :y
