Chat Area => General Discussion Area => Topic started by: Dazzler on 10 June 2007, 13:16:50
I went to see a 3.0 Elite est today..Very nice car apart from 1 door :( Anyway it had a modified air inlet system, basically the trumpets have been scraped and a custom ali box made to duct the air from the main airbox straight into the 2 airpipes on the plenum. Anyone else seen anything else like this?? any good??
sounds like a Mantzel system. someone has posted pics of one up here before...
cant remember who or when though :-/
http://www.omegaowners.com/forum/YaBB.pl?num=1177068349
Hi,
I think this is what your looking for :y.
Yes, very similar, except thet had used the standard air-box. Does this mod actually help in any way?
I would hazard a guess that if it made any improvement it would only be at the top end of the rev range. Removing the multi-ram will kill torque in the low to mid range though. It might give you a few more BHP on paper but in reality probably won't make the car faster.
Also, that setup looks prone to sucking hot air from the engine bay which won't help, although you say this particular one uses the standard airbox.
Not a reason not to buy a car if everything else checks out OK but if someone's been modding look for bodges elsewhere! You could always put the bagpipes back on.
