		Chat Area => General Car Chat => Topic started by: SHASSON on 30 June 2009, 20:39:42
				Hi , can anyone let me know how to set service light on my 3.2 V6 omega :)
 thanks Stephen
				..... didn't know we had one ....  well  my 3.2 doesn't !!!
 Check the handbook .. (page 12)
 http://homepage.ntlworld.com/andrew.reynolds983/Manuals/Omega2002Manual.pdf
 and confirm which light is on ... might be the EML which is a very different thing !!
				Whats the image on the light?
				Service light....? Not on an omega old bean. Engine light lit, maybe? Pre cat code?
				Hi sorry about service light?
 Engine electronics immobilizer ?
 Serious or what :-[
				Click the link below this post and follow the instructions for the pedal trick then post up your results ;) :y
				OK .. its the EML  and you have a 3.2 .. so go to this link...
 and do the PEDAL CHECK ... write down the codes you get and let us know .. we can then advise further
 HTH
 HTH
 Ooooo an echo ;D ;D
				[size=20]Echo[/size]        [size=16]Echo[/size]       [size=12]echo[/size]        [size=9]echo[/size]         echo     [size=11] ;D ;D ;D ;D ;D ;D[/size]
 (http://i89.photobucket.com/albums/k232/kenalovell/smileys/Laughing_RoflSmileyLJ.gif)
				any bets?
				P0340
				p0420/p0430
				Hi all,
 had a blonde hair moment in relaation to electronic immob.
 Did the pedal test and hey presto , it worked.
 Thanks for all the feedback lads, happpy motoring :) : :) :) :) :) :)
				Hi all,
 So what codes did it give you?
				HI the codes were as follows : 10 04  10 03 10
 Then dashboard was back to normal.
 Thanks again :) :)
				er, you have 5 digits. Trouble/fault codes are 4 digit. The 5th zero implys another code to follow or something like. You need to keep going and read all the codes. It could potentially save you money and a break down. And be sure to count correctly, difficult i know, the flashes are a bit quick.
