Chat Area => General Car Chat => Topic started by: JamesV6CDX on 02 July 2009, 16:48:34
Title: Well the Astra didn't last long...
Post by: JamesV6CDX on 02 July 2009, 16:48:34
Until I decided to, in true JV6 tradition, "Pull it's head off"  ;D
The oil loss is stupid, I have topped up with 3 litres, on 3 seperate occasions, since leaving Kevin's last Saturday.
I'm going to refurb the head and fit new stem seals at the first opportunity - may start this weekend, or the one after.
It's fine on a run, but when you idle for a while, and pull away quick, say after being sat at lights - it's embarassing!!
Still don't think it's piston rings - as it only does it after standing or idling.
What's the betting I find the cheapo stem seals in there  ::)
May look at skimming while it's off - especially being LPG'd as the extra compression may help - would appreciate advice first though  :y
Title: Re: Well the Astra didn't last long...
Post by: JamesV6CDX on 02 July 2009, 16:49:39
Head looks easy enough to remove, I've done a 1.8 Veccy and a 1.4 Corsa, all with the same small block engine.
Removing the inlet in situ is a pain - I recall it usually comes up with the head. And there's a tricky coolant pipe to get on at the rear of the head, too  ::)
Post by: andyc on 02 July 2009, 17:04:38
If its an 8v engine James you should have the head off and on the bench within an hour
Oh and be carefull of the LPG injectors (if its an OE system) as they did tend to pull the thread out of the manifold
Andy
Post by: Martin_1962 on 02 July 2009, 19:46:08
I bet it is the red seals
Post by: Entwood on 02 July 2009, 19:51:33
Would it be really, really rotten to start a poll/book on what bit(s) get left off on rebuild ???
I suppose it would, wouldn't it ??
Not having much luck lately James .... must be time for some of the "good" variety...   :y :y
Post by: Bent valve on 02 July 2009, 20:22:07
:) NOW THATS RIGHT OUT OF ORDER!`At least the guys had the good sense to remove 'mobile Omega mechanic' from his signature.
Sorry James I couldn't resist it ;) you perservere, we have all made similar mistakes  ;D
Post by: JamesV6CDX on 04 July 2009, 00:01:43
Forgot a follower on a previous rebuild on my own car - one off mistake - come clean, and never live it down...
The ones to worry about, are the ones who do not admit / learn from mistakes and pretend to be perfect.
We are all human.
Post by: JamesV6CDX on 04 July 2009, 00:13:21
I wonder if all these people would agree with you?
http://www.omegaowners.com/forum/YaBB.pl?num=1169241678/11
http://www.omegaowners.com/forum/YaBB.pl?num=1171909972/6
http://www.omegaowners.com/forum/YaBB.pl?num=1172348509/0
http://www.omegaowners.com/forum/YaBB.pl?num=1172413122/0
http://www.omegaowners.com/forum/YaBB.pl?num=1172438839/0
http://www.omegaowners.com/forum/YaBB.pl?num=1172938792/0
http://www.omegaowners.com/forum/YaBB.pl?num=1172938792/11#6
http://www.omegaowners.com/forum/YaBB.pl?num=1176290853/20#23
http://www.omegaowners.com/forum/YaBB.pl?num=1179648059
http://www.omegaowners.com/forum/YaBB.pl?num=1179816074/0#0
http://www.omegaowners.com/forum/YaBB.pl?num=1181418140/0
http://www.omegaowners.com/forum/YaBB.pl?num=1181723229
http://www.omegaowners.com/forum/YaBB.pl?num=1186101067
http://www.omegaowners.com/forum/YaBB.pl?num=1186662091/0
http://www.omegaowners.com/forum/YaBB.pl?num=1197324920
http://www.omegaowners.com/forum/YaBB.pl?num=1209845072/0
http://www.omegaowners.com/forum/YaBB.pl?num=1215891158/0
http://www.omegaowners.com/forum/YaBB.pl?num=1225713262/0
Post by: crazyjoetavola on 04 July 2009, 00:50:44
....could this push you over the edge James?
[media]http://www.youtube.com/watch?v=zGzL9n2_8a8[/media]
Post by: Vamps on 04 July 2009, 01:00:09
Have I missed something? what are you doing with an Astra???? :D
Post by: Bent valve on 04 July 2009, 15:22:15
Sorry mate , It was only a gentle pisstake :y and as I said we have all made mistakes!
Post by: JamesV6CDX on 05 July 2009, 00:02:49
No worries mate.  :y
Post by: crazyjoetavola on 05 July 2009, 00:07:36
I still belive in you James :) :) :y
Post by: JamesV6CDX on 12 July 2009, 22:00:58
:o :o
Just thought back to this.
Are these "red" seals the culprit ones that didn't last, that some pen pusher at GM decided to use, to save a few pennies?
I'd like to get my hands around his neck, if so...  >:( ;D
Mine are red, and there is evidence of much leakage on the inlet valves....
Post by: Martin_1962 on 12 July 2009, 23:30:15
:o :o
Yes
