		Chat Area => General Car Chat => Topic started by: JamesV6CDX on 14 August 2009, 16:27:22
				Need a full set of standard rings, to try and sort out the smokin' astra!
 VX want near on £300 a set, which seems steep. Seen them on ebay for £80 which is more like it - but, they only have them for the X16XE an not the Z16XE which I have.
 A member here sent me a link to an ebay auction for some, but they've now gone and no more in stock.
 Local parts place - can't get them
 Autovaux - need to make some calls
 Does anyone know a good reliable supplier of rings?
 Astra is using 1litre/100 miles, so it really, really needs looking at  ;D ;D
 Holy break James! your name's changed ... if i didnt look closely, i wouldn't have found out it was you!
 Anyway, I thought you had changed these already? Let me see if i can find some Z16XE piston rings again  :y
				Check this out James:
 http://cgi.ebay.co.uk/Vauxhall-ecotec-1.6-16v-piston-rings-std-size-2001-_W0QQitemZ270441863292QQcmdZViewItemQQimsxq20090813?IMSfp=TL090813146001r29302
 I think this is what you need  :y
				hi james. not sure if it's any use to you but have a look at this site.
 http://www.carpartsconnexion.com/vauxhall/searchresults.asp?f=Vauxhall&m=ASTRA-G&y=Any+year&cat=15&d=&p=&q=piston+rings
 hope it helps mate
				Just managed to get a Genuine VX set of std size piston rings for £72 + £10 postage  :-X :-X ::)
 Seems like a result to me.... that's from autovaux. They have now redeemed themselves!  :y
 Edit to add - thanks for all who supplied info :)
 Looks like next weekend I'm taking pistons out  :-/
				Cheers James. Good to know that you sourced the piston rings and that the Astra's gonna be sorted out  :y :y :y
 Thanks for the support mate.
 I've never done them before, but end of the day, there's nothing to lose - it's clapped anyway  :y
 No worries there mate  :y Always feels good to be able to help sometimes  ;)
 As you said, it's already clapped and from the testimonials on your website, you're a good mechanic  :y  So, am sure you gonna get them right  :y :y
