Chat Area => General Car Chat => Topic started by: HolyCount on 28 August 2009, 18:39:35
Wife has taken a liking to Astras and I fancy a convertible ... what should I be looking for in these (common faults, must haves, etc) ???
Clutch judders from cold can be a main issue.
Get one under warranty if your after a MK5.
The Mk3 is a nice drive, well the 2.0 is and are at rock bottom prices so you get alot of car for your money and cheap to run :y
carefull of the roof on the convertable
lots to go wrong
Astra G is the sweet spot.
Roof is not to bad unless your silly with it.
No real issues on them, pretty well screwed together.
Agreed on that :y
Boot tends to fill with water on the newer ones... Sister had one that leaked from day 1 and no matter what Vauxhall did they couldn't cure it :o :o :o
Thats not good :o :o
Type "Astra Burning Oil" into google, and then see what you think ;D
The 1.6 seems pretty well documented as one which burns oil (I'm about to do my piston rings) - but generally, they are good.
Clutch judder from cold, as said - but otherwise no real issues.
I like my Astra G with Factory gas :y
