Chat Area => General Car Chat => Topic started by: Lazydocker on 29 August 2009, 13:47:31
Title: V6 Passat Cambelt
Post by: Lazydocker on 29 August 2009, 13:47:31
Has anyone changed a VW Passat V6 cambelt before?
Just wandering if there's a special locking kit requirement and any hints/tips?
TIA
Title: Re: V6 Passat Cambelt
Post by: Del Boy on 29 August 2009, 14:14:05
Doesn't the whole front end have to come off for those?
Post by: Lazydocker on 29 August 2009, 16:13:19
Don't think so... Seems to be enough room but if it does they're actually quite easy to get apart :y :y
Post by: Del Boy on 29 August 2009, 16:38:48
Maybe the Skoda Superb is what I'm thinking of, but aren't they practically the same car?
Post by: KillerWatt on 29 August 2009, 18:08:48
Which model (inc year), and what engine code?
Post by: Lazydocker on 29 August 2009, 20:31:27
1999 on a V plate... It's a 2.8 4motion but don't have the engine code to hand
Post by: mathewst on 29 August 2009, 20:41:21
LSG I believe the whole front needed to be taken apart for the cambelt change for TDI models only. not the petrol ones
Post by: Andy H on 29 August 2009, 22:19:20
Changed the radiator on my wifes 1999 MK4 Golf this morning. A previous owner must have driven into a low bollard or concrete post so I have been waiting for an excuse to straighten out the brackets on the bumper.
It all came apart surprisingly easily and left me with totally unrestricted access to the front of the engine.
Don't know if that helps :-?
Post by: Andy H on 29 August 2009, 22:23:07
Just reread the OP. Cambelt will probably require removal of the drivers side engine mount, it did on the Golf and I assume it does on most transverse engine FWD cars with cambelts.
Post by: goonv6 on 29 August 2009, 22:37:32
Passat isn't transverse. TDI needs front removal, not sure about V6. Why not take it out and flush the system anyhow. I always fit a new water pump when doing cambelts so you could make sure the cooling system is tiptop.
Post by: KillerWatt on 29 August 2009, 22:46:31
Here's the destructions for you (right click, and select "Save Target As" from the context menu)
>>Timing Belt Replacement Instructions<< (http://www.natadsltest2.clara.co.uk/timing_belt_replacement.pdf)
Post by: Lazydocker on 29 August 2009, 23:29:46
Thanks for that... Seems that the front only needs pulling forwards to aid access so we'll see! Interesting to see a book time of 3.30 as she's getting it priced by a "specialist" because it may be the cause of some engine faults... I'll see whet he's going to charge before I volunteer as I've got enough on my plate at the moment! ::) ::)
Post by: Martin_1962 on 30 August 2009, 12:59:10
So why make it wrong wheel drive - seems like the ideal opportunity for a proper drive layput :-/
Post by: serek on 30 August 2009, 17:35:55
you lookin for about 5h work doing first time .
if you need hand let me know can come over and help I done few WV and Audi cambelts.
Post by: Lazydocker on 30 August 2009, 18:14:04
This one isn't... It's 4WD, biased slightly to the rear and great fun when it's going ::) ::) :y :y
Post by: Lazydocker on 30 August 2009, 18:14:43
Yep... I've done a few but not the V6. Might take you up on that offer :y :y
