Chat Area => General Car Chat => Topic started by: raywilb on 06 September 2009, 17:21:23
i took my mig to be tracked after work done on the suspension. it was pulling to the n/s and s/wheel was to the left, i took it back & and the only difference the s/ wheel was to the right. i went elsewhere & they showed me how far it was out, rectified it & checked all the suspension f & r ,all was ok & only was charged £14-98 + a free check in two weeks time. :y
waste to £15 mate
what they have done will not make a blind bit of difference to the way the car handles
you will need a full geometry set up
google wheels in motion and have a look there
probably one of the most covered topics on here. So worth a search but tracking is only a fraction of the possible adjustments on the omega. Camber being very important, and not covered in tracking set up, as it can wipe out tyres in a couple of k.
As said, full geometic set up after checking wishbone bushes stearing idler and springs for breakages wear and damage will see the best results.
don't want to throw a spanner in the works, but, I once had an Elite facelift Estate that we did loads of suspension work ourselves on . wishbones, camber set by spirit level, etc.
Took it to WIM and all but the tracking was spot on -
While I've no doubt wim are genuinely very good - it cost me over £80 for a tracking only adjustment... :-X
yes but lets face it James, you are one in a million. ;)
Impossible
Forum stats say We have 6488 registered members.
1 in 6488 aint too shabby though. ;D ;D
as far as i know there,s not a outlet near me that does full geometry. but those guys did spend forty minutesly checking all bushes, springs etc & gave the car the all clear. iv,e had the car 6yrs in december & its only had one set of tyres to date, but will probably need a set shortly. daft enough i,m going to a passing out parade 4/ 10/09 thats very near wim, so i,ll see how it goes . meantime i,m off to corfu later today 2 wks. :y
Expensive way of getting the tracking set, I agree. :(
Micheldever tyres charge per adjustment, so a single adjustment is only 15 quid or so IIRC. Tony undoubtedly has the best Omega knowledge though. :-/
Yes. But at least you knew before wrecking a pair of tyres to find out it was wrong.
What are the most common issues with Omega alignment:
1) Front Toe (Tracking)
2) Rear Toe
3) Front Camber
3) is the most common complaint, and one that any tracking or 4 wheel laser alignment won't do anything for. The usual end result is excessive, premature inner edge wear. This is also a setting that even most full geometry places make a mess of (the factory specs are unsuitable for a car that has a few miles under its belt).
1) is what most fast fit tyre places offer, and is kind of pointless, particularly on Omega, as it just ensures the front wheels are (almost) parallel.
2) Often called 4 wheel laser alignment. It has a fundamental flaw in that it ensures that the rear wheels follow the fronts, and has no reference to the chassis. You can have all four wheels perfect on 4 wheel alignment, but still completely wrong, and with a non zero thrust angle. In fact, with the Omega having adjustable rear toe, that is possibly likely!
Does anybody who has recentley been to WIM got the final adjusted print out of the camber/caster per wheel.
Reason I ask is I had mine adjusted by Southern based dealer with full laser equipment just before last christmas.(18k miles ago) and for about the last 4 weeks I have been suffering from rear nearside going flat every few days or so.When I checked with tyres off car, both front and rear nearside tyres have a 25mm virtually bald band around entire tyre diameter on the very inside edge and almost certainly the reason rear tyre is loosing air.
Now I know tyres may be on their extent of life but I am worried that if a full set of 4 is refitted they will now go same way.
I have found the print out I was given after the final adjustments and would be curious to see how they compare with the WIM set up.
Sorry but should have put up final reading as per print out.
FRONT
Caster .... Left 5.0 degree Right 5.6
Camber... -1.8 -2.0
Toe......... 0.00 0.00
REAR
Camber.... -2.4 -2.3
Toe.......... 0.10 0.10
SAI 13.9 13.6
Included Angle 12.1 11.6
Set Back 0.0 -0.1
Your quite right imho. Your new tyres will go the same way very quickly unless the set up is corrected. I dont have the spec to hand but i am sure of you give Tony at Wim a call he will quite happily advise.
And i would ask the previous company to sort you out some new tyres seeing as avoiding you exact situation is the whole point of the exercise.
i seen that idiot on the TV wheeler dealers using a crappy tracking kit on a Merc 190 Cossie that had bad tyre wear issues all he done was set the steering straight!
When i know that the 190s suspension is more adjustable than an omegas and is best suited to an establishment like WIM too!
Just had mine done (4wa) and here are the results in reverse order:-
front
min max before after
0.0 +2.63 +2.10 +1.40 Total Toe
min max before after min max before after
+4"40' +6"40' Caster +4"40' +6"40'
-2"25' -0"55' -2"24' -2"27' Camber -2"25' -0"55' -1"48' -1"48'
-1.10 +0.70 partial toe +3.20 +0.70
SAI
+1"15' +2"45' Curve +1"15' +2"45'
before after
+0"00' -0"04' Set-back
Rear
+1.36 +3.99 +2.00 +2.90 Total Toe
-2"35' -1"15' -1"38' -1"15' Camber -2"35' -1"15' -1"26' -1"16'
+1.80 +1.50 partial toe +0.20 +1.50
before after
+0"07' +0"03' Set-back
+0"06' +0"00' Thrust angle
I think I may have got my deg and min's signs mixed up (wrong way round) but you get the drift.
Haven't a clue wether I've wasted £50 on 4WA :-/
Had the same on ours after I did the shocks, wishbones, & droplinks.
We (my mate & I) went "old school" on setting it up after we put it all back together (protractor, string, level, and a couple of bits of 2x1) and when it went on the ramp at WIM...the front end was (to quote) "nothing wrong with that mate, and we won't get it any better".
Computers are pretty good, but nothing will ever take old school away.
FRONT
Camber... -1.8 -2.0
REAR
SAI 13.9 13.6
Set Back 0.0 -0.1
That will wipe the tyres out :o
What should the correct reading be then TB.
Had it rechecked again yesterday and readings were set at :
Camber
front Left -2.1 Right -1.8
Rear -2.3 -2.2.
So is this incorrect as according to machine and operative that was perfect for age of car and mileage.
camber should be 1 degree 10 mins :y
this is the trouble with 'in the green' its far too wide >:(
Specification printout from their computer shows a min and max specification.
Front Camber min = -2.4 max = -0.9
Rear.........................-2.5 -1.2
Strange thing is car is incredibly stable and appears totally true with no vibration or tram lining
I was advised that the rear suspension donuts should be considered as worn so worthwhile having replaced and evidence of leakage on rear shock absorber so again advised to replace the set.
No effort ws made to convince me that they were touting for the work as they were very happy to show me where and how they were secured and potentially what was involved in their replacement,so on face value they seemed to know their stuff.
Camber
Rear -2.3 -2.2.
Its all very well having the equipment, but if you don't know how to use it..... ;)
It has been proved time and time again that with the amount of camber you have will cause extreme, premature inner shoulder wear.
Being 'green' on the machine quite simply isn't enough - any monkey could achieve that.
