Chat Area => General Car Chat => Topic started by: HNO3GOH on 15 October 2009, 19:12:40
should i say two hole in the block ;D ;D
This is a few of the bits found on the tray plus part of a small end
(http://i304.photobucket.com/albums/nn195/cjjm26/Engineparts003.jpg)
This is the hole on the drivers side of the engine
(http://i304.photobucket.com/albums/nn195/cjjm26/PHONEPICS14OCT2009309.jpg)
and this hole was by the aircon pump
(http://i304.photobucket.com/albums/nn195/cjjm26/PHONEPICS14OCT2009312.jpg)
When i got the heads off i found the bottom end to be in abit of a mess, two snapped con rods and one of the pistons was in three large parts, I thinks you did a good job James :y ;D ;D ;D
Hats off to you Jim, proper breaked up that one is! ;D ;D ;D :y
Whoops :o
Nice to know I did the job properly, then ;D :y
Did the heads survive ?
They did :o I will get some pics of the piston on for you but yes i think it's safe to say you did a dam fine job :y
It certainly sounded like a lot broke... it let go near the red line ::) :D
So, what do we think was the cause of failure?
Your driving ;D ;D ;D ;)
Anyway, bit of liquid metal and it'll be good as new :y :P
The oil looks clean... ::)
It looks to be bigend.
This is looking down on no1, nice chunk missing from the bottom ;D
(http://i304.photobucket.com/albums/nn195/cjjm26/PHONEPICS14OCT2009310.jpg)
Yeah, a bit of chemical metal, that'll be good as new :P
At least he did the job right, no cutting corners [smiley=evil.gif] [smiley=evil.gif] [smiley=evil.gif]
True -- he didn't cut them -- he tried to blow them off :o
Near the redline? or way beyond it :o
When I first got my manual 2.5 V6 (and being used to a motorbike with a 10500rpm redline) there were a few occasions where it hit the (soft) limiter and I glanced down at the tachometer and saw the needle pointing somewhere between 3000 & 4000.
I think what happens is that the ECU cuts the sparks (or half of them) and gives a duff reading to the tacho.
I once had a spectacular big end failure on a 60's Royal Enfield. The results looked very similar to the photos but with aluminium crankcases and con rod. I never did work out what caused it (but I was flat out downhill at the time ::))
A beano comic and some filler should do the trick :y chemical metal's too dear!
Patch the holes up on the crankcase and just run it as a V4 ;D :y
Now you,re talking! ;D :y
