Chat Area => General Car Chat => Topic started by: Ken T on 16 November 2009, 15:19:29
Title: Stag LPG kit at good price
Post by: Ken T on 16 November 2009, 15:19:29
For anyone considering LPG, there is a 4 pot Stag kit on ebay for £175. http://cgi.ebay.co.uk/LPG-autogas-conversion-injection-kit-AC-STAG-4-300_W0QQitemZ250531207168QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item3a54d2d800
I think this is the kit used by several people on here. Obiously you need to get a tank, etc  but there are enough of them floating around.
Ken
Title: Re: Stag LPG kit at good price
Post by: tunnie on 16 November 2009, 15:25:07
'dangle berries' i just paid £225 for the same kit  >:(  ;D
Post by: Ken T on 16 November 2009, 15:30:26
It just shows the difference in 2nd hand is very small. Mine cost £140, with the slight advantage of having a drilled manifold and a tank, but money wise very little between them.
I see there's another 2 petrol price rises coming soon.  :'( :'( :'(
Ken
Post by: tunnie on 16 November 2009, 15:35:45
Ken
How close on your manifold where the injectors mounted?
Post by: Lazydocker on 16 November 2009, 15:47:53
I personally wouldn't buy this kit as it's not as complete as the one we get supplied. It's also not the same kit... Different vaporiser for a start :y :y
There's no software, cable, pipework, brackets, hose clips, nuts etc, all of which will probably set you back another £150 minimum, which makes it more expensive (I think) than the supplier we use :y :y
Post by: Ken T on 16 November 2009, 16:03:29
I was going to post photos later, but...
Here are the LPG nozzles relative to the petrol injectors : (http://i159.photobucket.com/albums/t155/lapbits/PICT2893.jpg)
Hers is one nozzle, curious it has about 4 holes into the manifold. :
(http://i159.photobucket.com/albums/t155/lapbits/PICT2894.jpg)
I can't really comment on how good or bad this postion is, the car is a bit rough at low revs, but it hasn't been tuned at all. I fitted new plugs yesterday and its a lot better, apart from the missfire on one pot which is due to damaged spark plug rubber boot.
Ken
Post by: Lazydocker on 16 November 2009, 16:07:28
Position looks OK... Could have been a bit closer to the petrol injectors but not by much :y :y
Post by: Kevin Wood on 16 November 2009, 16:07:34
.. not to mention we know the support that Teilo offers is good. I'm concerned that they say it's limited to 136 HP too. That sounds marginal for a 2.2 and I wonder where the restriction is?
Post by: Lazydocker on 16 November 2009, 16:08:52
Support and warranty :y :y
It's probably the Vaporiser... That's not the one we were supplied  :y :y
Post by: tunnie on 16 November 2009, 16:09:56
Ken
Cheers for that, its good to see  :y
What kind of MPG are you getting at the moment on gas? My runs will be 90% motorway, hoping to get 25mpg. (2.2 manual)
Post by: tunnie on 16 November 2009, 16:11:56
Not sure on that too, Stag kit i got (almost exactly same pictured) on another auction, listed it as 145bhp.
Post by: Lazydocker on 16 November 2009, 16:12:48
Ken
Can't see that being a problem... I got about 21mpg (Actual figure) on gas in my 3.0 Auto last week on a run to Liverpool and back, with a bit of town driving too, without sparing the horses :y :y
Post by: Kevin Wood on 16 November 2009, 16:21:45
True. And the one we have is supposedly good for 350-400BHP. :o A 3.2 on full bore certainly drags the output of that down a fair bit. I would be fitting 2 of them if I had any more power.
Post by: Lazydocker on 16 November 2009, 16:27:37
I still think is a foible of the omega causing the slight lag at full chat :-/ :-/
Post by: Lazydocker on 16 November 2009, 16:28:38
Probably another different Vaporiser :y :y
Make of kit only really relates to the ECU
Post by: tunnie on 16 November 2009, 16:31:32
This is the kit i bought:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=120493003362&ssPageName=ADME:B:EOIBSA:GB:1123
Vaporisor is the same (although refered to as a Pressure Convertor) - TOMASETTO Alaska vaporizer
Looks like i was done by £40  :(
Post by: tunnie on 16 November 2009, 16:32:19
a quick google suggests its capable of 140 bhp.... which for my motorway use is fine i think / hope!
Post by: JamesV6CDX on 16 November 2009, 16:35:36
I don't think you can go wrong for £225 - it's essentially all there, bar a couple of hoses and clips....
Post by: tunnie on 16 November 2009, 16:37:42
Already got lots of big pipes for coolant, as we used on that other project. Just LPG pipes from injectors to vaporiser, some clips, and a rack to mount the injectors.
Post by: Ken T on 16 November 2009, 16:39:43
Yes, mine is labelled Bigas Sgis. The ECU however is made by AEB, and badge engineered by OMVL, Bigas and another 2 companies. I have a de-dongled version of the OMVL soft, must see if it runs my Bigas ECU OK.
Ken
Post by: tigers_gonads on 17 November 2009, 20:45:58
what sort of prices are we talking about for a diy lpg kit for a 3ltr v6 estate ?
i would want a donut tank though  :y  need lots of boot space  :(
who on here has something similar ?
Post by: tunnie on 17 November 2009, 20:53:14
PM Chrisgixer.... about £800 for the kit  :y
Post by: feeutfo on 18 November 2009, 11:09:38
Yep. About that. Estate will need a lie flat donut as opposed to the upright for saloon obviously. Differant mounting points and valve.
Post by: Lazydocker on 18 November 2009, 12:45:52
And cheaper ::) ::) :y :y
Post by: JamesV6CDX on 18 November 2009, 16:27:17
Anyone got a contact number they could PM me for Teilo?
He's not answered my emails...
Post by: Lazydocker on 18 November 2009, 16:29:09
He's probably away in the Ukraine again ::) ::)
PM Sent
Post by: JamesV6CDX on 18 November 2009, 21:49:36
Mucho Gracsias...
Post by: tunnie on 18 November 2009, 22:58:35
Mucho Gracsias...
Can you get me a 80L tank and other bits and bobs too  ::)
Post by: Lazydocker on 18 November 2009, 23:25:42
Mucho Gracsias...
I can... Just post up your Credit Card details, billing address etc... ::) ::) :o :o ;D ;D ;D
Sorry... Couldn't resist!
Probably best to have a trawl for tank suppliers. I know Teilo had mine drop shipped from another company so it's worth ringing around :y :y
Post by: tunnie on 18 November 2009, 23:42:47
Mucho Gracsias...
Ta, from what i saw £200 was the going rate for 80L, not much on fleabay, and the amount of LPG sellers with shite websites is staggering  :o
Post by: Lazydocker on 18 November 2009, 23:54:38
Mucho Gracsias...
Oh yes... Sounds about right for a 4-hole tank. Make sure you get one with the valves fitted for you :y :y
Post by: Kevin Wood on 19 November 2009, 00:06:36
Yes.. Not too difficult to fit them, but makes for a nail-biting first fill. :o
Post by: tunnie on 19 November 2009, 09:16:41
Noted!  :y
Quick question on fuel lines, not sure if the kit i got contains fuel lines? The other cheaper kit  >:( Which looks the same, mentioned i needed "Copper tube or polyflex pipe 6mm (to connect with tank)"
Post by: Kevin Wood on 19 November 2009, 09:38:53
Doesn't look like it comes with fuel line. 6mm Polyflex will do the job. Don't bother with copper. You will need fittings to terminate the polyflex hose depending on what's on the vapouriser and multivalve. Probably worth using 8mm for the filler unless you're going for a 4 hole tank?
Post by: tunnie on 19 November 2009, 09:39:52
just rang a supplier for tanks, this was the price list (all +vat)
4 hole 80L tank - £211 (including valve & bolts)
Mouting brackets - £26.25
Filler - £28.55
FillerHose (standard length) - £16
Delivery £15
Brings total to £323, sound about right?  :-/
Post by: Kevin Wood on 19 November 2009, 09:46:34
Not really sure, as I only got 1 bill for the whole lot!
Maybe slightly more than I expected, TBH. :-/ Perhaps the exchange rate has made it so. Worth giving Teilo a call to see what he can do IMHO.
Also be aware that 4 hole tanks have a fabricated filler hose a bit like a hydraulic hose with ends crimped on - so you need to know where everything is going to end up before you know how long it needs to be!
Multivalve tanks you can cut filler pipe to length as it's just copper / polyflex tube. In fact for a 4 pot I would probably go for a multivalve. I went 4 hole because it looked marginal on power with a V6.
They can fill quicker too, on the right pump!
You will also need rubber hose for the vapour and vacuum connections.
Best to see what turns up and we'll sort out what else you need. :y
Post by: tunnie on 19 November 2009, 09:49:49
Cheers, i have the kit, here, i'll take some photos and post up  :y
Post by: Ken T on 19 November 2009, 09:53:19
Filler - £28.55
Delivery £15
That is quite a bit, you could get a 2nd hand tank a lot cheaper. I was selling a 2nd hand 60L tank with fitting kit for £45.
Ken
Post by: Lazydocker on 19 November 2009, 10:01:50
Filler - £28.55
Delivery £15
Sounds too expensive to me :-/ :-/ :-/
I know mine was part of the kit but I find it hard to believe he only charged me £327 for the rest of the kit
Post by: tunnie on 19 November 2009, 10:16:12
cheers, i'll keep looking!
Post by: Kevin Wood on 19 November 2009, 12:29:21
Has anyone checked Teilo's prices recently? Just wondering if the exchange rate has pushed them up? I wouldn't be surprised, as he was obviously working on fairly small margins.  :-/
Post by: Lazydocker on 19 November 2009, 12:31:49
Dunno... Had a lot of interested people contact me recently ::) ::)
