Chat Area => General Car Chat => Topic started by: cruisetopoland on 03 December 2009, 15:06:44
Title: A new one would have been easier and cheaper...!!
Post by: cruisetopoland on 03 December 2009, 15:06:44
Bought my Omega on 6th October and it is nearly ready now after endless work and advice from OOF members.  Would have done a few things differently knowing what I know now, but this is the job list so far:
2000 Vauxhall Omega 2.2 CD auto
Schedule of Works
6th October 2009
Major 100,000 mile service completed
Engine flush and additional short oil change to semi synthetic
Spark plugs replaced-NGK
Pollen Filter replaced
Both wiper blades replaced, arm springs lubricated
Brake fluid replaced
Additional works completed:
Complete 3 part exhaust system fitted, plus brackets
Rocker cover gasket replaced
Front brake discs replaced
New Mintex brake pads fitted, front
New Mintex brake pads fitted, rear
Wash/wipe system flushed, jets re-aligned
Road wheels changed front to back
Tracking and alignment
Wheel balancing
MOT test, passed no advisories
Full HPI registry check
VOSA MOT and history check
Presentation
Interior shampoo valet including boot
Exterior cutting compound and wax finished
Underside washed and inspected
Engine bay hand detailed
Front and rear number plates replaced
OE Vauxhall Persia paint stick supplied
Body checked and touched in as required
During October 2009
1000 mile test and checks, parts replaced:
7th October 2009
Multi-function VX cruise control stalk fitted
27th October 2009
2x ignition key outer cases replaced
2x remote key batteries replaced
29th October 2009
Osram Nightbreaker H1 headlight bulb +90% upgrades fitted
Philips Xtreme H7 main beam bulb +90% upgrades fitted
6 LED clear white sidelight bulb upgrades fitted
Entire car inspected and adjustments made as necessary
Lubrication of moving parts
Detailed valet
Number plate bolts replaced with correct colour
Mat clips replaced
6th November 2009
Ludlow Motors Vauxhall Main Dealer
Workshop inspection, parts noted for repair 7th November
Diagnostics code read-no faults
Outstanding recalls or notifications checked against Vauxhall database
Central computer updates via Tech2 for:
Gearbox software
Engine management
Climate Control
Cruise control fitment enabled via Tech2
7th November 2009
welung666
Another additional short oil change with semi-synthetic oil
New OE Vauxhall oil filter and sump washer fitted
Coolant drained, flushed, replaced to high strength
Under-bonnet alarm switch replaced
First aid compartment latch replaced
NS door panel top repaired to OOF modification
Missing grommets and screws replaced as required
NS headlamp replaced complete
OS headlamp replaced adjusters, refitted
Assorted corroded minor fasteners replaced
Twin horns removed, inspected, front horn replaced
Fuel flap release motor replaced
NS front door check strap tightened and washers replaced
OS front door check strap tightened and washers replaced
Expert inspection to engine and body carried out
Scuttle panel drained and drain hole cleared
10th November 2009
Vaughan Garage
New headlights aligned to MOT standard
Under-body inspection on ramp by MOT tester
Federal tyre fitted to NSR wheel to create correct matching set
Wheel balanced
14th November 2009
welung666
Automatic gearbox fluid flushed and replaced with Dexron3
AT filter inspected and cleaned
VX OE transmission gasket fitted
Car run to fill torque convertor and topped-up with ATF
Tested second-hand catalytic converter fitted
Lambda sensors checked
2 tanks super-octane high detergent fuel used
16th November 2009
Markhams Garage
New ATF and gasket checked
Automatic transmission fluid level topped up with Dexron3
22nd November 2009
welung666
Handbrake and rear brakes stripped, cleaned, lubricated and adjusted
Handbrake cable lubricated adjusted
Exhaust manifold gasket replaced, three previously broken studs noted
Exhaust system, catalytic converters and sensors leak tested.
All cabin door latches and catches adjusted
Missing towing eye supplied and checked
Wynnes valve lifter treatment added
26th November 2009
Vaughan Garage
Exhaust manifold removed and cleaned
All original studs removed and disposed of
Removal of 3 broken studs
New multi-layer VX manifold gasket fitted
10 Vauxhall OE manifold studs fitted
Manifold heat shield bolts drilled out and replaced
All exhaust joints and sensor fittings inspected
Complete system engine-tail pipe confirmed leak-free
2nd December 2009
Kwik-Fit
Brake fluid changed to Mobil DOT4
Front brakes stripped and copper greased to resolve squeal
Tracking and alignment checked and re-done, plus front directional tyres swapped NS/OS to check for radial pull as part of tracking price
Steering wheel centred correctly
Wheel balancing
Tyre pressures checked
Road test and brake check
Spare wheel inspected and inflated to correct pressure
Spare wheel well inspected and cleaned
Towbar checked and touched in on ramp
Battery level checked
Battery tested on condition meter
It is now nearly right and I am starting to enjoy it-let's hope the Poland trip goes smoothly.
Sincere thanks to welungg666 for his help, advice and support.  Without this, I would have sold it by now.  He calls it "Trigger's broom"  ;D ;D
Thanks to everyone for their query responses and general help.
Great site  :y :y :y :y :y :y
Title: Re: A new one would have been easier and cheaper...!!
Post by: cruisetopoland on 03 December 2009, 15:59:49
Also did this...
http://www.omegaowners.com/forum/YaBB.pl?num=1256203694
It's becoming quite nice now  ::)
Post by: Ken L on 03 December 2009, 16:10:39
You couldn't have bought a new one, not an Omega, and if you had...just think how much fun you would have missed and how much knowledge about the car you would have lost out on, and how much satifaction and pride you would have missed. :)
Post by: zirk on 03 December 2009, 16:53:49
Off to Poland eh!, a good place to get an LPG conversion done or at least get the Bits, a lot cheaper out there.
Chris.  :y
Milej podrozy, baw cie dobrze i duzo Polskiego piwa - Na zdrowie!!
Post by: Varche on 03 December 2009, 17:52:51
Is that all?  hardly done anything!
V
P.S. If you are thinking of selling I will give you 600euros (including delivery) and I will run you to the airport afterwards. ;D
Post by: cruisetopoland on 03 December 2009, 18:03:20
Chris.  :y
Duze piwo, duza wodka, duzy Bigos, duzo spania  :y
Post by: cruisetopoland on 03 December 2009, 18:05:20
V
If you'd asked me three weeks ago....... ;D ;D ;D
Was fed up with the solve one problem, find another six  ;D ;D ;D
Post by: Omegadoha, Desert Member on 03 December 2009, 18:23:48
Sometimes you wonder whether the car is supposed to serve you or if you're supposed to serve the car.  ;D
Post by: zirk on 04 December 2009, 00:32:20
Chris.  :y
Idz za ciosem  :y
Post by: cruisetopoland on 04 December 2009, 12:54:23
Chris.  :y
Idz za ciosem  :y
 ;D ;D ;D
(Thank God for google translate on this one!!)
Post by: zirk on 04 December 2009, 14:25:33
Google starts adding and changing words  ;D
Milej podrozy, baw cie dobrze i duzo Polskiego piwa - Na zdrowie!! -
"Have a nice trip, enjoy yourself, and plenty of Polish Beer, Cheers!!"
Idz za ciosem -
"Go for it!"
Well thats according to my Human Polish Translator sitting next to me, unless She's spinning me a Line?
The only Polish I know cant be repeated on here, oh, and my old favorite which gets you out of all sorts of trouble -
Nie wiem Nic -
"I know nothing!"
Anyway have a great time, Chris  :y
Post by: cruisetopoland on 04 December 2009, 14:52:12
Idz za ciosem -
"Go for it!"
Nie wiem Nic -
"I know nothing!"
My favourites:
nie rozumiem (I don't understand)
przepraszam (sorry/excuse me!)
gdzie jest toaleta (where is the loo?)
 ;D ;D ;D Google translator got "idz za ciosem" as "go for blow" !!!  ;D ;D ;D  Tied in nicely with big beer, big vodka, big bigos, big sleep- go for blow!!!
I have done three Polish courses at college but I'm still lost-my wife is an excellent translator and always helps if needed.
Post by: cruisetopoland on 04 December 2009, 14:53:58
Idz za ciosem -
"Go for it!"
Nie wiem Nic -
"I know nothing!"
What is it with Omegas and the Polish?  There are loads of members with Polish connections on OOF-have had lots of pms  :y
Post by: serek on 04 December 2009, 15:53:59
Idz za ciosem -
"Go for it!"
Nie wiem Nic -
"I know nothing!"
we like good solid cars :)
also we have on polish forum section in english
http://forum.omegaklub.eu/forumdisplay.php?f=97
everyone welcome  :y
Post by: cruisetopoland on 04 December 2009, 15:56:43
Idz za ciosem -
"Go for it!"
Nie wiem Nic -
"I know nothing!"
everyone welcome  :y
Dziekuje bardzo dla informacje  :y :y
Cheers, Serek  :y
Post by: serek on 04 December 2009, 16:06:03
prosze bardzo
you welcome :y
Post by: feeutfo on 04 December 2009, 16:35:22
an impressive list. Mine was similar.(lost it in a phone swap fiasco) Only now is it starting to drive straight and behave as it should with all the service work done.
 You may be interested to know, i could have had a brand new dark burgandy 2.6 cdx in 2005(i think, may have been 04) for £12000. It was said to be the last one vx had, if you can beleive that.....i didnt as it came from the mouth of a car salesman.
Post by: cruisetopoland on 04 December 2009, 16:39:08
I sat in a last of line new Omega that was offered for similar money, my mate nearly bought it...
My Omega still is not "absolutely" right, but I am, some say, a little pernickity.....the list goes on.  And on.
Thanks for the feedback  :y
Post by: albitz on 04 December 2009, 18:17:01
could have been worse,you could have bought a v6 :D ;D
Post by: cruisetopoland on 04 December 2009, 19:49:26
My thoughts too  :y  I love the V6, but even my humble, tidy 4pot is complex enough-and this has been a lot of work.
I looked in the Lotus Carlton engine bay and shuddered with admiration for any mechanic who could tame it.... ;D
Post by: cruisetopoland on 08 December 2009, 16:04:31
Schedule of Works
6th October 2009
Wheel balancing
Presentation
During October 2009
7th October 2009
27th October 2009
29th October 2009
Detailed valet
Mat clips replaced
6th November 2009
Gearbox software
Engine management
Climate Control
7th November 2009
welung666
10th November 2009
Vaughan Garage
Wheel balanced
14th November 2009
welung666
16th November 2009
Markhams Garage
22nd November 2009
welung666
26th November 2009
Vaughan Garage
2nd December 2009
Kwik-Fit
Wheel balancing
The list goes on  >:(
Now having:
new track rod assemblies fitted both sides
new ball joints both sides
throttle bodies cleaned
My friends can't believe how obsessive all this is for an old virtually worthless car....I see their point....but hopefully this is IT now  ;D ;D
I think my head needs scanning for fault codes-where do I plug in the "My Naff Code Reader"?
Post by: cruisetopoland on 29 December 2009, 13:13:28
Schedule of Works
6th October 2009
Wheel balancing
Presentation
During October 2009
7th October 2009
27th October 2009
29th October 2009
Detailed valet
Mat clips replaced
6th November 2009
Gearbox software
Engine management
Climate Control
7th November 2009
welung666
10th November 2009
Vaughan Garage
Wheel balanced
14th November 2009
welung666
16th November 2009
Markhams Garage
22nd November 2009
welung666
26th November 2009
Vaughan Garage
2nd December 2009
Kwik-Fit
Wheel balancing
Now having:
XX new ball joints both sides NO
Add to this a new thermostat, carbon cabin filter, NS and OS track rod assemblies.....
Next: NS and OS wishbones and bushes, bankruptcy!!
Post by: Martin_1962 on 29 December 2009, 15:13:21
Use poly bushes?
Post by: Agemo on 29 December 2009, 23:30:38
Just one question, what is the recommendation for these Carbon pollen filters?  I am on paper, right or wrong?
EDIT:- Just seen The Boy's post, Facelifts NEED Carbon ones.
Post by: steve2.5cd on 30 December 2009, 22:32:10
Chris.  :y
EH ???????????
Post by: tunnie on 30 December 2009, 22:33:31
Facelift climate systems are designed to work with carbon ones...
Post by: tunnie on 30 December 2009, 22:34:52
Chris.  :y
EH ???????????
Polish... something about beer!
Post by: cruisetopoland on 30 December 2009, 22:36:02
Chris.  :y
Nice journey, have fun and a lot of Polish beer-cheers!
Big beer, big vodka, big cabbage stew, big sleep  :y
EH ???????????
Polish; apologies  :y
Post by: Omega 37 on 30 December 2009, 23:31:21
I just got one, dealer told me it should be a carbon one for facelift. He always seems to know his stuff unlike many!!!!!!!
