Chat Area => General Car Chat => Topic started by: feeutfo on 04 March 2010, 00:43:10
Pants! >:( ;D
Welcome to the club [smiley=beer.gif]
yeah, i reckon you earned a beer after the last week.
no light on though :P...yet....did the pedal trick just to see....pre cat. Arse.
Just delete all codes and ignore ... :) takes less than 30 secs with the maxscan .. :)
Not had a bad run so far. Think yours must be one of the last 3.2 not to have had it.
Before moving the sensors my light would come back on within hours of it being reset.was a real Pain
yes, i've been thinking of getting a reader, trouble is i'll want something that does live data, and she has a polo, and is likely to want a golf next. Am i likely to get something that does mine and vag as well?
Although i do have vag.com, or whatever its called, on the lap top that has a com port, just need a lead to read the polo.
Chris once I've got my "My Naff Code Reader" sorted I'll be selling my Sealey reader. It reads and clears any OBD2 car and does limited live data as well.
Hi Steve, yes it hasnt done badly, i'm not been looking forward to that bloody light coming on though.
Thanks Lee, i'll bare it in mind. Ta.
These codes do seem to lurk without putting the light on sometimes. Maybe it was only a brief error condition not sustained for long enough to light the EML?
You are welcome to borrow my ELM327 cable if you want to have a play with it? Does engine codes and live data on OBDII engines and there's a variety of software that will support an ELM327 cable.
Pants! >:( ;D
Congratulations Chris!
stop being tight arses and buy some blanking plugs and get em moved ;D,wellung did mine and never been on since. :y
Thanks Kev, interesting, worth a look. :y
I only did the pedal trick after resetting the lpg to 1.1 bar and calibrating at that pressure. Wondered if it might have upset it. Should have pedal tricked before calibration, and again after.
Pants! >:( ;D
"Thanks" not one of my better achievmets. ;)
yeah, he's a good lad. :y
0420 seems to be quite common fault nowadays, even with other brands. We've got a -00 model Primera which has generated this also, now both our cars have 0420 occasionally... :D
If I get the Sealey VS8702 does anyone know if it will work on the following please:
Omega 3.2 2002
Audi A3 2.0tdi 2007
Phaeton 3.0 tdi 2009
Signum 1.9cdti 2007
Also anyone used the Sealey TA120 current tester? Is it a good unit for Omega 3.2?
