Chat Area => General Car Chat => Topic started by: Marks DTM Calib on 24 March 2010, 09:34:22
....and removes the need to take engines apart again!
Changed a thermostat for a member on here last night as it was stuck open.
Now this particular power plant has a checkered history as mentioned on a previous thread as the engine should be a 2.6 but, it certainly has pre 98 2.5 heads fitted!
Anyway, having removed the offending stat, it became quite clear why the stat was faulty.
(http://i23.photobucket.com/albums/b394/Marks_DTM_Calib/Maintenance%20Guides/DSC00005.jpg)
(http://i23.photobucket.com/albums/b394/Marks_DTM_Calib/Maintenance%20Guides/DSC00006.jpg)
You can see a huge length of sealant stuck in the stat........
So, let this be a lesson to all.....excessive use of sealant is not good and cleanliness is essential!
i just used a small dab of grease on the o-ring when I did the stat on the 3.0, that sealant almost looks like black cam cover sealant?
I suspect it was cam cover sealent.....the trick with sealent is to just use a wipe of the stuff.....not so much that it ouzes out when compressed into some huge additional O ring!
wonder if they thought it needed it, the o-ring i got with our kit was quite thin, and did not fully fit depth / width of the grove on the stat, its been watertight though :-/
A shame, especially as it looked like a decent stat.
So, inappropriate use of (excessive) sealant and a need to do the whole job again, plus stat and a/freeze ...
Still, not sure why 'that' bolt got it's name.
-Must change my sig to 85° !
I reckon an engine is only clean enough to reassemble if you'd be confident licking the bits.
thats why my dishwasher gets so much use on engine bits :y
If I could do that I would make a fortune in films ;D
