Chat Area => General Car Chat => Topic started by: tunnie on 24 March 2010, 17:58:35
Lazydocker is arriving tomorrow so we can start my LPG project, just finished getting everything together, list of little bits here and there need is quite a bit, done about 3 trips to screwfix to get odd holescrews, cone drils and bolts.
Decided to put all the gear i have out on the garage floor to make things easy to find:
Throttle body, manifold, drill, soldering iron, pipework (cooling & polyflex)
(http://dl.dropbox.com/u/803897/Omega/LPG/PrepDay/DSC00593.JPG)
Evaporator, tank valve, tank box, loads of water T's L's, filters, loads of bolts, bag was only £4, did not say how many came, think i might have gone a bit OTT ::) - Ah well could always do with a few spares ;D
(http://dl.dropbox.com/u/803897/Omega/LPG/PrepDay/DSC00594.JPG)
Main Loom, pressure sensors, and outer filler
(http://dl.dropbox.com/u/803897/Omega/LPG/PrepDay/DSC00595.JPG)
ECU, 90 degree filler, manuals and paper work
(http://dl.dropbox.com/u/803897/Omega/LPG/PrepDay/DSC00596.JPG)
All the gear, ready for the car in the background :)
(http://dl.dropbox.com/u/803897/Omega/LPG/PrepDay/DSC00597.JPG)
All that stuff to gas a car.
Good Luck to you friend.
When you have finished yours' you are more than welcome to play with mine, I think I could have phrased that better. ;D ;D ;D ;D ;D
Looks like you're all set. :y Hope it goes well. Sorry I'm not around to
jinx it help. ;)
Looks like you're all set. :y Hope it goes well. Sorry I'm not around to jinx it help. ;)
Cheers for all your help so far :y
Good man Tunnie :y
Go to it with a heavy dose of Confidence and a light touch on the tools ;) :y
Good luck mate...
Still keep thinking about LPGing mine... not sure still...
Is my R reg 3.0 Elite worth LPGing? :-? I dunno... maybe? ;D
Good luck mate...
Well mines a X plate on 137k (lot for a 4 pot)
But seen 4 pot petrols in the scrappy with 250k, i expect to save £10 a day, and it will be paid back within 5 months on business miles alone.
Even if i only get 2 more years of use out of the car, which is about right given my current millage. It will have paid for itself time and time again :)
Good luck with it all :y :y
Something missing from that list of bits ......... :)
A tank ??? :)
A tank ??? :)
He has got a Challenger 2 on order.
I told him he needs a Stako ::) ::) ::) ::)
90L Stako Torpedo tank with frame in the boot already :) (not mounted)
I would hope not .. 'tis a family site .. :)
I prefer the 100L ones ::) ;D
Glad you're all set... I've changed my mind after TB's car ::) ::) ;D ;D
See you in the morning
Oh... Forgot to add, I have 2 Sammy's so we can do anything :y :y
Eh Lazytinker.... do you want to come and play with Mrs. Loo-knee's? ;D ;D ;D
got a big sammy and to mini's as well so should be able to
bash through... do anything. Got to dig through my filing system ::) and find my drill set ;D
Does look very interesting Tunnie, looks like you've got enough assorted parts to be building a second car ;D
If you fancy a hand, i.e with the easy stuff liking making the tea I'm more than happy to pop over for a bit :D
Eh Lazytinker.... do you want to come and play with Mrs. Loo-knee? ;D ;D ;D
Really... Not sure Mrs LD will like that :-/ :-/ ;D ;D
Patience is a virtue oh sleepless one ;D ;D
Just making some enquiries about tanks (for estates) at the moment, then we'll be going :y :y
Anyway... You hadn't asked until then :-?
Not my place to say yes... But Tunnie assures me there's plenty of Bacon butties to be cooked ::) ::) ;D ;D
Be nice to meet you :y
Tunnie, have you found out which wires you need to tap into at the ECU?
And have you got the wiring diagram for the kit or do I need to bring my own?
Your very welcome Josh, need someone to load the BBQ with bacon ;D
Seriously though your welcome to pop down if your not doing anything :y
I'm working on it. :y
There is a wiring diagram too.
Should have soldered some tails into the ECU harness ready last night. Completely overlooked that. :(
Got the main diagram which shows which colours go where and such :y
Got the soldering iron here and some heat strink (some-ware) so should not be an issue :y
Ta... Wasn't sure if you'd have time so was covering other options :y :y
Not too worried about cutting in to the ECU loom TBH... I think it's too fiddly to get on the pins on the 2.2 isn't it? :-/
Mmmm bacon :D
That sounds about the right skill level for me.
If you don't mind, I'll pop down if I've got some free time...what sort of time?
heat shrink, whats a matter with gaffa tape ;D ;D
Tunnie, you do know that you cant run the wiring loom through the passenger window dont you ?
Senator. ;) :D ;D :y
Hoping to be the owner of an LPG 3.2 myself shortly (If I can contact a certain chap.) ::)
Tunnie... I'll need a hand getting my tool box out of the boot tomorrow... Nearly killed myself putting it in today :o :o ::) ::)
Mmmm bacon :D
All day... I should be there by 9 at the latest, traffic permitting
Josh - Any time mate, in fact anytime over next 3 days :y
LD - Err i am not the strongest chap in the world as many who have met me will comment ::) - Back the car in and we can use the boot as the tool box ;D
Albs - Course you can, Senator wiring job did not look great, but it worked ::)
I managed to lift it in on my own, so you'll be fine... 4 wheetabix for brekkie young man ;D :y
Just a quick one. Might well be a stupid question:
I assume it's a Z22XE with Simtec management?
TIS seems to show a Motronic diagram too. :-/
think all 2.2 petrol in Omega are Z22XE?
OK. Pinouts for SIMTEC:
+12v ignition switched feed Black X84 Pin 64
Tachometer Green X84 Pin 62
Mixture control Lambda X83 Black Pin 57 signal pin
X83 Grey Pin 8 ground pin
If you look at the routing of the looms from the ECU X83 is the connector where the loom heads round the engine itself. X84's loom heads through the bulkhead into the car.
I think the Lambda sensor pin you want is pin 57 but I've included pin 8 in case I've got them the wrong way round.
The ECU connectors are a bit dense so I find the best way is to find the pin on the connector, trace the correct coloured wire from that pin up the loom a little and scrape the insulation and solder there then insulate.
You might need to solder in connections to the petrol injectors as the connectors are part of the cable tray that sits over the injectors.
Yep. Just saw some references in TIS to Y22XE and a motronic ECU.
gross
Thanks Kevin :y :y
Looking forward to that now ::) ::)
