Chat Area => General Car Chat => Topic started by: albitz on 25 March 2010, 22:02:11
Part number on gearbox is 96016628 - does anyone know if this denotes which box it is please ? :-/
That part number stuck into EPC comes up with ...
TRANSMISSION, ASSY., WITH CONVERTER (IDENT BD) X25XE -V1999999 96016628 7 01 393 1
so my guess would be ar25 as its for the 2.5 engine ..
but it is a guess .. EPC does NOT list ar25/ar35 anywhere that I could find .. :(
HTH ...
whats the difference between them,is the 35 beefed up for the 3.0-3.2 ?
much stronger box .. ar35 also used on the diesels ... all to do with the torque they can handle I believe
ar25 = 250 Nm
ar35 = 350 Nm
but I could well be wrong .. seems to be becoming a habit ... :(
ar25 = 250 Nm
ar35 = 350 Nm
Only if someone has upgraded it :y :y
also the gearboxes can have their inners removed and up graded with ar35 bits have a look if there is any paperwork to prove this.
It is a box on fleabay which looks like it could be picked up for next to nothing (nearly finished, no bids) and its quite close to me. If I knew it was an AR35 I would buy it, but it looks more likely to be a AR25 so I think I will leave it. ;)
I have two known good AR35 gearboxes here one is off Vader which maybe sold if thats any help to you :y
Thought you said you did not want a gearbox when I asked you? :-?
I dont need one, but an AR35 for potentially 99p would be too good to pass up - I could sell it to you if you come and collect it. :y :D ;D ;D ;D
