Chat Area => General Car Chat => Topic started by: Jimbob on 05 April 2010, 08:39:20
Title: LPG Guides
Post by: Jimbob on 05 April 2010, 08:39:20
We are in the process of adding a new index section to the maintenance guides dedicated to LPG Fitting & problems.
Huge thanks to all involved in the creation of the guides, some real team work going on  :y
fair few to add, so they will move from test to the guide section in dribs and drabs  :y
Title: Re: LPG Guides
Post by: Jimbob on 05 April 2010, 09:20:36
Thats 4 guides in with more to come.
Huge thanks to the 'LPG crew'
Cheers Lazydocker, Tunnie, Kevin et al.
Post by: tunnie on 05 April 2010, 09:26:15
guides are looking good  :y
Post by: feeutfo on 05 April 2010, 11:56:14
LD has asked if i could rustle something up re fitting a donut tank, should be able to sort something in the next couple of weeks if/when it ties up with an insurance issue on the rear bumper.
Post by: PhilRich on 05 April 2010, 17:03:46
Keep up the good work fellas!, don't forget, this numpty, is going to need all the help I can get when the time comes, especially with the electrical/electronic connections! ;D ;D ;D ;D ;)
Post by: Entwood on 05 April 2010, 17:12:51
All looks good ..  :y :y :y :y
Lots of hard work, both on the actual work and the guide ... well done mate  :y :y :y
Post by: Kevin Wood on 05 April 2010, 17:15:38
I am working on a section covering the electricals. :y
Post by: feeutfo on 05 April 2010, 18:24:47
is now a.good time to ask about the tow bar electrics guide as well ?  :-X
Post by: Lazydocker on 05 April 2010, 19:13:29
Right, so KW is doing the electrics (I assume connections only?) and I'll cover cable runs when I do the front end sections.
Chris is doing a Vertical Toroidal tank section.
Anything else anyone can think of?
Kevin, do you want to do a section on the software, ECU upgrade and calibration/mapping too or do you want me/Chris to do it so you've got more time for other things?
Post by: TheBoy on 05 April 2010, 19:13:33
Pikey!
Post by: Lazydocker on 05 April 2010, 19:15:05
Pikey!
Your point being? Bearing in mind you want at least one of the 3 members who have/will have tow bars to help re-fit/finish the LPG on silver bullet :-X ::) :-?
Post by: Kevin Wood on 05 April 2010, 19:18:28
No Problem. Leave it to me. :y
Post by: Kevin Wood on 05 April 2010, 19:20:25
PMSL. Last time I saw the silver bullet it was relying on a pikey bar as its' sole method of propulsion.  :D
Post by: Lazydocker on 05 April 2010, 19:22:57
 ;D ;D ;D ;D ;D ;D ;D
So will the Golden Nugget now :-X :-X :-X
Post by: TheBoy on 05 April 2010, 20:45:52
I was thinking of filling exhaust with petrol, and lighting.....
Post by: Lazydocker on 05 April 2010, 20:54:03
Just let it run for a few minutes in it's current condition ::) ::)
Post by: Martin_1962 on 05 April 2010, 21:00:23
Want anything from me?
Post by: Lazydocker on 05 April 2010, 21:07:37
I think we're pretty well covered... Only really dealing with the Stag kit TBH :y
Post by: Martin_1962 on 05 April 2010, 21:08:48
I am not overly enamoured with the Romano kit except that the injectors are flap design and do not need a filter
