Chat Area => General Discussion Area => Topic started by: Taxi_Driver on 27 June 2007, 19:38:52
Title: It could be the end?
Post by: Taxi_Driver on 27 June 2007, 19:38:52
Of my 2001 veccyB 1.8 dual fuel.  :-/
Its been running on 3cyl on petrol for a while now, but fine on lpg.
ECU is complaining injector ciruit on no3 cylinder is open ciruit.....so probably knackered petrol injector.
Last night it started running on 3 cylinders on lpg as well  :(
So today in hope of fixing it, 1st changed the plugs.....no difference.
Then i swapped the coil pack from my veccyC onto it....no difference.
So then not having a clue what to check for next.....i took it to my local garage.
After explaining what i'd done.......1st thing they did was a compression test.
No3 cylinder zilch compression  :(
Their diagnosis was probably valve knackered....or head gasket.
But they say it doesnt really matter which it is......coz the head has to come off anyway to replace the valve so if it isnt a valve then the heads of anyway so they would just change the gasket.
Garage estimate £300-£400 to fix  :(
As this Veccy has done now 210k miles and only has a couple of months left on its taxi plate before its too old......im not gonna be spending that kinda money on it.
So do i try to flog it as project for someone (or for the lpg system)......or turn it into a project for me to fix it  :-/
I was pretty confident on sorting out/replacing the petrol injector......tho following the book of lies it does seem pretty involved.
But taking the head off it.....dunno if im capable of that.....well probably could but its the putting it back together that worries me. That nasty job of cam timing.
Want a project Tunnie  ;D
Title: Re: It could be the end?
Post by: tunnie on 27 June 2007, 19:40:50
a tunnie project might be closer than i thought!  :-X
Post by: Timbuk on 27 June 2007, 19:45:43
Depends what it owes you really :-/
Post by: Markie on 27 June 2007, 19:51:26
off with the head stick a breaker head on and new timing belt....and Bobs yer uncle  :y
Post by: Taxi_Driver on 27 June 2007, 20:02:16
Zilch really.....but wouldnt like to see it scrapped as Ive probably spent about 2k in the last year on it....
Gearbox/clutch/exhaust system/droplinks/steering bushes/just about nearly every engine/gearbox mounting/cambelt kit at 200k/new rear&front pads 2 weeks ago/ 4 new tyres 2 weeks ago
Post by: Taxi_Driver on 27 June 2007, 20:07:11
Problem then is re-installing the lpg system.....tho spose it would be possible swap inlet manifolds over  :-/
Post by: Timbuk on 27 June 2007, 20:08:37
Get what you can for it then as a project maybe best bet  :-/
Post by: Martin_1962 on 27 June 2007, 20:34:58
How much is ONE valve?
Post by: bob.dent on 27 June 2007, 20:38:48
OY..........I am definitely NOT his bloomin' uncle!! >:(
;D ;D
Post by: JamesV6CDX on 27 June 2007, 22:59:32
PM Sent TD -
I have two ideas for this car - I think you may like the 2nd :y
Post by: Markie on 27 June 2007, 23:23:44
;D ;D
Forgot to say Uncle Bob - Green beast is fixed  :y :y :y
Post by: JamesV6CDX on 28 June 2007, 07:25:14
We could be very close to a deal, here ;D
Post by: Taxi_Driver on 28 June 2007, 07:29:47
Probably about a tenner, plus head gasket, plus cambelt (dont think i would bother with the kit, as i know the rollers etc have only done 10k)
Post by: JamesV6CDX on 28 June 2007, 18:29:35
TD and I have made arrangements on this one... hopefully the car will be back with me very soon :y
Post by: Taxi_Driver on 28 June 2007, 18:52:11
Mind you, for that price......im not cleaning it......you can bl**dy do that yourself  ;D
Or convince a nice man from Birmingham to give it a polish  :D
Post by: Taxi_Driver on 28 June 2007, 18:57:39
Oh and James.....remind me else i'll forget.
You might as well have the brand new book of lies for it.....coz i wont be buying another veccyB
And ive got a brand new vx air filter you might as well have as well  :y
Post by: STMO123 on 28 June 2007, 19:03:19
What are you going to replace it with TD?
Post by: Dazzler on 28 June 2007, 19:25:20
So is the 3.0 estate going on the market now then JamesCDX
Post by: Taxi_Driver on 28 June 2007, 20:20:37
Its kinda scuppered my plans a bit......going wrong like that....bl**dy inconsiderate car  >:(
If it had of lasted another month or two then it would of been plan A
But now its......ex veccyB driver is having my veccyC next week.....after i have the gas problem sorted out.....its started switching to petrol all time again  >:( Oh and its got a bearing going......bit of a bearing noise coming from i think either alternator or aux belt tensioner......you can see the tensioner bouncing about a bit on idle.....so its one of the two....hope its the tensioner......thats the cheaper of the two!
Getting the exhaust manifold sorted on my Omega is now a top piority........
Then its Plan B........which i havent thought of yet......
There thats clear on my plans...........as mud  ;D
Post by: STMO123 on 28 June 2007, 20:30:09
Sorted! :-/
Post by: JamesV6CDX on 29 June 2007, 07:30:56
TD,
Seeing as you're letting me have this veccy at such a good price, I will have a look at that exhaust manifold issue for you on the 2.2.
How badly is it blowing, and are there any studs snapped clean against the head?
Post by: Taxi_Driver on 29 June 2007, 08:28:50
TD,
Cheers m8  :y
Well, ive had the manifold off to have a look.....one might be, the other has definately snapped inside..think its drill time but i wasnt confident of doing that myself so i shoved the manifold back on for the time being.......ticks quite nicely for a few mins when cold.....then goes quite.
