Chat Area => General Car Chat => Topic started by: davethediver on 21 July 2010, 16:12:26
Anybody know how difficult a job it is to change the clutch on a MK1 ford focus (its a 1.8 tdi) :question
Think its on its way out >:(
TIA Dave
with the front subrame dropped its fairly easy ,if you try with the frame in place its tight but can(I've done it) be done
Are you sure its the clutch and not the clutch master cylinder which is a common one on the Focus ;)
No idea pete will let you have a look at it at some point in the next week.
Driven autos for that long can't remember what a slipping clutch is like.
Just seems that when it goes into fourth and fifth that the revs go up but takes a bit longer for any pick up if you get where im coming from? Any suggestions?
Just hope it s not this DMF thing i read about on the ford forum although very little of what was said on there made any sense ;D ;D
late mk1s tds had them
Thats would clatter when starting up and cause vibrations....not clutch slip :y
Thats good news then no clatter just seems to rev a bit before picking up in forth and fifth :-/
