		Chat Area => General Car Chat => Topic started by: Omegatoy on 26 July 2010, 20:14:36
				to paperclip or pedal test an 02 aguila? anyone know??? got one thst is only running on a couple of cylinders and the garage reckon its a sensor fault!!!
				Can't do any harm trying :-/ ;)
				Might be worth trying the pedal test too.
.. or it might well talk to a generic OBDII reader.
				for your info the pedal trick does work on the aguila!!
got codes 0301 and 0302 assuming ten flashes equals a zero?
anyone know what these represent? off now to have a search but always worth asking here!!
If the same as her Astra, 0301 will be a miss-fire on No 1 cylinder & 0302 a miss-fire on No 2 cylinder. New plugs 'cured' it for a week, then a new (generic) coil pack for a couple of days  :'( and a bottle of injector clean seemed to sort it completely  :-/
				the codes are as andy said :y :y,checked with autodata
diamond geezer!!! lost me uplink as soon as i posted so couldnt check!!! actually changed the plugs yesterday and it ran better, then changed the coilpack , seemed to run better too but then had to pack in so, will check toninte when its cooler!! thanks Andy
				damn!!! begining to think something else is wrong here now!! i was busy rebuilding the engine on the first aguila, when peter decided to wash the 02 car engine off with engine degreaser and a power wash!! so yesterday it appeared to run better after plugs and coil pack change, but today after the wash it now has codes 0300, 0301,0302, now the oil was really bad(milky) and the filter was actually in 2 pieces!! it hasnt used any water today from the coolant tank but there appears to be a fair  bit in the cam cover after running it, and it has a missfire?
im thinking head gasket but hoping its something else!!
ideas??? :o
