Chat Area => General Car Chat => Topic started by: omegod on 05 August 2010, 12:25:12
Pickep up a clean 206 for a song, it needs wishbones for the MOT , heard these can be a ghastly nightnmare to get off which will involve a 5 foot scaff bar and chains! anyone done these?
I will let you know tomorrow as I have a 206 outside waiting for wishbones to arrive :y
best of luck Henry, I would put this on the same peg as an ATF change on the Miggy.
One bolt wont clear the driveshaft drivers side and I just cut the other one off with a grinder. Spring compressors would make it a lot easier!!
Nightmare >:(
they aint that bad 2 do. i take the bottom of the strut out the hub then take the ball joint bolt out and remove the bottom arm. would change them 4 u but im showing my car this sat at castle combe :y :y :y :y
Nightmare >:(
best I empty my swearbox first then :P :'(
I've changed a set of 206 wishbones away from my workshop with nothing more than a socket set. You have to fiddle about a bit to make sure you don't pull on the driveshaft too hard while the bottom ball-joint is disconnected, but other than that it's reasonably straightforward. 2hrs from car driving all over the place to car driving in a straight line.
just finished the 206 that I am doing,I removed the hub nut and swung shaft out of the way which gives access to front bolts,left hand side was easy but struggled a bit with the right hand one getting the arm low enough to re-engage ball joint pin,enjoying coffee and fag break now :y
All done myself too, bit of a faff but saved a few quid :y
