Chat Area => General Car Chat => Topic started by: unlucky mark mv6 on 07 August 2010, 17:49:07
Really fancy the idea of doing this,but how do you all do it,and what with.Take it you rub it down first to a fairly flat surface,and then polish.I do have a 2 speed makita mop if that helps at all,and i believe you use autosol. :-/
You need to remove the 'stipples' from the Plenum. I'd do this with a detail sander, or DA. Start with a 600grit paper, then finish with a 1200grit.
Then you can get on with polishing.
Will be a time consuming, very boring job.
There was quite a detailed thread of how to do it 12/18 months ago. :ppled bloody good when done.
I remember seeing a thread somewhere aswell,think it might have been in the gallery. :-/
I was always told to stop polishing my plenum or I would go blind ::)
Trust you pete ;D ;D ;D
Can you type in a larger font please Pete, cant read what you put. ::)
:-/ I can read it no problem at all................
...........Through my binoculars. :D
Have you seen the Countess' plenum? He must have spent ages polishing his. :-X
320 grid and sanding machine.. then 800 and 1200..
dont try with bare hand , machines are always quick..
Have a word with steverubberduck, he did his - photographs are gone sadly;
http://www.omegaowners.com/forum/YaBB.pl?num=1240679262
http://www.omegaowners.com/forum/YaBB.pl?action=viewprofile;username=4F48594A594E495E5E594E58495F570B093C0
Thing is you cant wet sand by machine,unless you know of an ingenious way of doing so. ;)
Shame all the pics are gone. :-/
Anyone fancy a plenum polishing meet. ;D ;)
Me thinks the pink one would be up for this ;D ;D
for plenum, wet sanding is not necessary..
