Chat Area => General Car Chat => Topic started by: omegod on 10 August 2010, 20:18:48
Replaced my Crank sensor with one from the stealers about 6 months ago and got code 19 again along with huge starting problems!! >:(
I thought these were reliable? problem is I was originally given the wrong one which sat in my boot as a spare for 6 months previous until I came to change it, dealer said no guarantee on it as I had had it so long :(
how did you run the cable?
Well away from the manifolds TB!
Just wondering if too much movement on the cable. I think the concensus is the cables can go brittle....
I can get you a genuine Bosch item if you wish?
Dean
Had similar experience - brand new Vx crank sensor, routed away from exhaust, lasted a couple of months then failed completely. Fitted replacement - no issues to date.
Dean
Hello Dean , How much is a new bosch crank 8-)sensor for a 2003 3.2 ? thanks
I am pretty sure there is a warranty with VX parts maybe worth a phone call. :y
Worth sh*t Daz - when mine packed up car wouldn't start at all. Vx said refit b*ggered one and get it over to them to check - if faulty they would replace FOC. Cost of getting it to them 11 miles away - cheaper to fit another - cheating barstewards >:( Thats the "new" Vx customer service for you.
Well contacted them today and they ummed and arred now want me to bring it in for a check via diagnostic, if it's the crank sensor they will replace it but if not they will charge me £89, car is driveable but not sure whats the best/easiest option.
Suspect they will say it's routed wrong or some gubbins :-/
