Chat Area => General Car Chat => Topic started by: joshwyatt on 24 October 2010, 22:06:23
Title: CID's
Post by: joshwyatt on 24 October 2010, 22:06:23
If you're after a CID the best way is to buy a whole car I think, as it almost works out cheaper in the end. Take the CID, put a GID in it and sell it on for not much less than you bought it, if any less at all.
I was lucky and bought a damaged Omega with a CID, but there are currently two Omega's on ebay that are pretty cheap currently with CID's.
I'm not the seller of these vehicle, nor do I know the vendor;
http://cgi.ebay.co.uk/2000-VAUXHALL-OMEGA-ELITE-3-0-V6-AUTO-94K-MILES-SAT-NAV-/360313000091?pt=Automobiles_UK&hash=item53e454109b
http://cgi.ebay.co.uk/Vauxhall-Omega-2-6-CD-Saloon-manual-Leather-Satnav-/130447190910?pt=Automobiles_UK&hash=item1e5f422b7e
Title: Re: CID's
Post by: aaronjb on 24 October 2010, 22:09:55
Knowing my luck I'd end up not being able to shift the car on for some reason.. I have zero luck when it comes to buying & selling cars ;D
Title: Re: CID's
Post by: humbucker on 24 October 2010, 22:18:18
will a cid work with any stereo then? i thought you had to have one of the 2013/2015 NCDC units?
Title: Re: CID's
Post by: joshwyatt on 24 October 2010, 22:21:48
The CID only works with the 2013 or 2015 as you say  :y
Title: Re: CID's
Post by: RobG on 24 October 2010, 22:41:51
You would have to remove the head unit as well, as the CID is paired to it
Title: Re: CID's
Post by: hotel21 on 24 October 2010, 23:14:08
Both the head unit and the display can be set to factory mode with Tech2 (depairing).  Display then replaced with, say, a GID instead of the CID and set back up.
The original headunit can easily stay in place.
Title: Re: CID's
Post by: Andy B on 24 October 2010, 23:16:24
but swapping both bits would be easier for mortals without a Tech II  ;) ;)
Title: Re: CID's
Post by: pscocoa on 25 October 2010, 10:01:20
I have a spare CID - well spare in the sense I have all the bits - just need the TFT screen to replace the faultyunit -  I think the proper replacment is no longer available. Anybody got an alternative screen to the Toshiba?
Title: Re: CID's
Post by: TheBoy on 25 October 2010, 10:02:16
And don't use that piece of shite "My Naff Code Reader" to do this task - I have an NCDC2015 here that an OOF member buggered up pairing up with "My Naff Code Reader".
I was able to recover the display and the CD Changer, but the main board is as much use as a used johnny smeared in dogshite.
Still, I'm not complaining, his loss, my gain ;)
Title: Re: CID's
Post by: PhilRich on 25 October 2010, 14:46:23
I was able to recover the display and the CD Changer, but the main board is as much use as a used johnny smeared in dogshite.Still, I'm not complaining, his loss, my gain ;)
Whoever said the English Language wasn't expressive, obviously isn't a member of the OOF!  ;D ;D ;D ;D ;D ;)
Title: Re: CID's
Post by: feeutfo on 26 October 2010, 00:00:45
I'm sure H is slapping his legs as we speak.  ;D
