Chat Area => General Car Chat => Topic started by: Welung666 on 24 November 2010, 07:56:16
Called out this morning to an 04 plate Vivaro 1.9CDTi that wouldn't start. Stored codes are:-
P1635 Glow Plug Controller Error
P181A ??????
P0530 A/C Boost Pressure Valve
P1635 again???
Warm engine, just wouldn't restart. Anyone any ideas on the 181A code and a reason for non starting?
I suspected cam sensor as they are a favourite on these but no code showing for it.
TIA, confused of Dudley :y
Just googled the P181A code and nothing listed for Vx. Found it on a Ford forum though - P181A Clutch Actuator Changeover Solenoid / Open. Very odd indeed.
Check for Renault codes, Renault engine :y
Yep (very shite and unreliable) Rernault engine in these.
OK, just to close this one....
He had taken it to a back street garage to diagnose a revving problem (revs raising to 1k then dropping to nearly stalling). They told him he'd need a new number 1 injector @ £330!
Turns out they'd stripped the injector loom back to investigate and not refitted the cam sensor plug fully!!! Useless to$$ers!!! A bit of switch cleaner and fully push the plug home and it fired straight up ;) I also fixed the revs problem, the usual corroded multi-plug in the passenger side fuse box :y
I've had him on the phone again.... His Veccy B estate has grabbed onto the key in the ignition and won't let go ;D ;D Guess what I'll be doing tomorrow morning ;D ;D
(goes to Dudley to find a house with a Vivaro and and a 'free' Vectra on the drive)
;D ;D ;D ;D
Glad you got it sorted mate :y
