Chat Area => General Car Chat => Topic started by: RobG on 30 November 2010, 12:44:10
Title: Rigid Towing bars
Post by: RobG on 30 November 2010, 12:44:10
These any good for towing a Mig?
http://cgi.ebay.co.uk/HEAVY-DUTY-towing-bar-sping-loaded-damper-car-tow-rope-/380098472310?pt=UK_Recovery_Tools&hash=item587fa26976
Title: Re: Rigid Towing bars
Post by: Elite Pete on 30 November 2010, 12:47:18
I suppose it depends what you are towing and how far. I bought an A frame and its been brilliant  ;)
Post by: RobG on 30 November 2010, 12:48:31
A miggy, about 30 miles
Post by: Welung666 on 30 November 2010, 12:49:09
They aren't bad Rob but you need a 2nd person to steer the towed car. I also have an A-Frame and it's a doddle to setup and use :y
Post by: Andy B on 30 November 2010, 16:32:29
It looks very similar to Machine Mart's, if it's the same they're not that good. When mine folded itself in half by the spring I borrowed a solid home made bar, .... far better.
But an A frame is better still.  :y
Post by: Omegatoy on 30 November 2010, 21:01:53
got to say the person driving the towedcar has to keep the bar reasonably straight or it can bend,
mine has towed a fully laden transit twin wheel high top 45miles no problem, it also towed a transit transporter with a mondeo on  the bed no worrys, the mig didnt even break into a sweat either!! :y
Post by: bestie26 on 02 December 2010, 21:21:39
ive got a homemade one made from a scaffolding bar with a "D" link (think thats what they are called)  welded to each end ive towed loads with it including a transit van and found it a lot better than the shop versions
unfortunatly its a bit bent now thanks to my mate as i towed a car up my drive and turned left onto main road and the tit forgot to take the steering lock off! resulting in a smashed bumper and a bar thats now shaped like the front of a mondeo (still tows ok tough)  :y
Post by: Kneepad on 02 December 2010, 23:03:58
 ;D ;D ;D ;D  I love it.
Post by: david036 on 04 December 2010, 10:57:00
Sorry to go off topic slightly, Do you get any damage to the towing car whe using the A-Frames?  It just seems from looking at them that there could be some damage done to the bumpers?
Post by: Andy B on 04 December 2010, 14:15:31
I suppose you could do if the car was any lower than an Omega, the lower rubber strip on an Omega was just compressed when I used an A frame to tow one. No damage done though.  :y
Post by: david036 on 04 December 2010, 14:25:50
Ah thanks for the reply Andy B!  That does make perfect sense to have two cars ideally the same height!!!
Post by: Andy B on 04 December 2010, 14:49:48
It doesn't quite work like that  ;). The tow ball of the towing car is generally the same height from the road no matter what car it is,  the towed car is connected to the A frame via the lower wishbones so what determines whether the A frame will rub is the relationship between the height of the lower wishbones to the height of the bottom edge of the front bumper from the ground.  :y
Post by: vauxfan2k on 04 December 2010, 15:09:16
we used a tow dolly to take this car the 70 odd miles up to my place, needless to say there was no tailpiece left on the exhaust when we got home  ;D ;D ;D
(http://i495.photobucket.com/albums/rr320/vauxfan2k/DSC00357.jpg)
