Chat Area => General Car Chat => Topic started by: venom on 11 January 2011, 19:41:15
Title: Skover project
Post by: venom on 11 January 2011, 19:41:15
I'm picking up a 1991 Skoda Rapid at the weekend as a small project which some of you will know already.
What I intend to do is junk the 60hp 1.3 lump and replace it with a 160hp Rover 1.6 K series engine running a Megajolt ignition system, breathing through a set of Suzuki 1200 Bandit carbs, completely striped out interior with a full roll cage to stiffen it up, drop it 35mm, rear disc conversion & I'm sure I'll think of other tweaks as I go along  :D.
This post will be a bit slow as I'm off to hospital next Thursday for an op on my foot so will be out of action for a few weeks but when I'm able it will be full steam ahead & I'll get pictures up Monday of the car.  :y
Title: Re: Skover project
Post by: Radar on 11 January 2011, 20:29:18
Hope the op goes as smooth as possible and good luck with the project :y
Post by: Welung666 on 11 January 2011, 20:39:38
Looking forward to the pics :y
Post by: venom on 11 January 2011, 21:22:17
Can't wait to get started, I've have measured the block for the adapter plate for the transaxle to the Rover block and as far as the flywheel goes I can use the Skoda flywheel, the Rover flywheel is a similar size, but uses a 200mm friction plate, and the ring gear is in the wrong place so to use the Skoda flywheel apart from more mounting bolts, the centre bore is 35mm for Skoda and 34mm on Rover so to get the flywheel sat central I'll get a turned a brass sleeve pressed in and turned it out to 34mm  :y this will allow me to make up a 34mm mandrel and bolt the 2 flywheels concentrically back to back and have look at the mounting bolts & drill them appropriately  :y
Post by: Kevin Wood on 11 January 2011, 22:19:42
I would go the whole hog and fuel inject it, TBH. Megasquirt instead of 'jolt and a set of bike throttle bodies + injectors off ebay. :y
If you ever need any help with anything Megasquirt, drop me a PM. Been playing with them since 2003.
Post by: venom on 11 January 2011, 22:28:34
Cheers Kevin I'm going to hold you to that as Electronics/Electrical aren't my best subjects  :-[
Post by: millwall on 11 January 2011, 23:42:44
Looking forward to the pics  sounds like a good project :y
Post by: venom on 12 January 2011, 06:44:41
Cheers  :y
Post by: Martin_1962 on 12 January 2011, 12:03:51
What are they doing to your foot?
Post by: venom on 12 January 2011, 12:29:13
It's what they call a heel shift & Tendon transfer operation
If you don't like graphic pics don't click the link  :y
http://www.thefootandankleclinic.com/article113section13.htm
Post by: Martin_1962 on 13 January 2011, 10:00:57
Flat feet operation :o :o :o :o
I had a toe straightened as it was curved under another - slightly too long toe, so tendons pulled it at a funny angle
Post by: venom on 13 January 2011, 18:50:49
I'm not getting it done because I have flat feet, mine is for the tendons as 15 years ago I was dragged under a 10 ton forklift and broke my ankle but I have to have the same op to fix the tendons  :'(
Post by: venom on 15 January 2011, 21:25:04
12 hours before i pick the Skover project  :D :D :D :y :y :y
Post by: venom on 18 January 2011, 16:48:53
Well here she is a 1990 Skoda 136 Rapid.
(http://i4.photobucket.com/albums/y117/kenmacritchie/004-10.jpg)
(http://i4.photobucket.com/albums/y117/kenmacritchie/005-12.jpg)
(http://i4.photobucket.com/albums/y117/kenmacritchie/007-12.jpg)
(http://i4.photobucket.com/albums/y117/kenmacritchie/008-10.jpg)
She's generally good just the odd bit of rust & two water leaks but 80% OK cant wait to get the op out of the way and get cracking  :y
Post by: tidla on 18 January 2011, 18:26:05
will you be keeping the bonnet scoop!?
Post by: venom on 18 January 2011, 18:36:55
Errrmmm F*****G NO or the poxy screw on body kit :-[ or the bumpers  :y
Post by: Hannah Judes Dad on 19 January 2011, 00:20:58
The bumpers look like they belong on a Saab 99  :)
Post by: Welung666 on 19 January 2011, 16:44:27
I'm almost ashamed that was attached to my A Frame ;) ;D ;D
This may not end up a Skover either from the conversation Venom and I had... It may end up as a Skauxhall ;D ;D
Post by: Kevin Wood on 19 January 2011, 20:16:19
Easy does it! Don't want too much weight overhanging that rear axle or it'll be a bit of a Skoditchfinder. :o
Post by: venom on 19 January 2011, 21:08:58
I'm afraid it will be a Skover as the transaxle wont take the torque of the Vauxhall lump  :(
Post by: Welung666 on 19 January 2011, 21:22:48
AR$E :(
Post by: tidla on 19 January 2011, 22:21:07
are these the skodas that (forgot the tech term) carry the weight on the driveshafts with the difficult to remove rear drums?
Post by: venom on 21 January 2011, 18:38:31
Well did a small bit today, took off the poxy body kit, front and rear bumpers & rear panel in readiness for the engine removal over the weekend.
(http://i4.photobucket.com/albums/y117/kenmacritchie/001-12.jpg)
(http://i4.photobucket.com/albums/y117/kenmacritchie/002-10.jpg)
(http://i4.photobucket.com/albums/y117/kenmacritchie/004-11.jpg)
(http://i4.photobucket.com/albums/y117/kenmacritchie/003-9.jpg)
Post by: venom on 22 January 2011, 06:44:40
If it was only this easy to get to the front of the Omega's engine for the cam belt  ;D
Post by: r1 on 22 January 2011, 20:21:43
as its the 136 it has the later engine that went into the new skodas.
looks someone has tried to make it go faster with that carb on it.
years ago i used to race a 130 skoda good fun cars.
Post by: venom on 22 January 2011, 20:34:00
Cheers r1 what sort of racing ?
Post by: r1 on 22 January 2011, 21:45:56
it was auto grass racing had a few wins against mk1/mk2/escorts  as they where good off the line with the engine over the drive wheels.
Post by: venom on 25 January 2011, 20:41:03
I've looked at the flywheels.
(http://i4.photobucket.com/albums/y117/kenmacritchie/Image0461.jpg)
The Rover flywheel (Left) is a similar size, but uses a 200mm friction plate and the Skoda is a 190mm plus the ring gear is in the wrong place. So I looked at mounting the Skoda flywheel to the crank. Apart from more mounting bolts, the centre bore is 35mm for Skoda and 34mm on Rover.
So to get the flywheel sat central, I got a brass sleeve made, pressed in and had it turned out to 34mm
(http://i4.photobucket.com/albums/y117/kenmacritchie/Image0462.jpg)
This allowed me to make up a 34mm mandrel and bolt the 2 flywheels concentrically back to back and have look at the mounting bolts.
2 holes nearly line up, and the 5 remaining (4 bolts and 1 dowel hole) can be drilled into the Skoda flywheel. The 2 that nearly line up will be slotted the 3mm so I now have the required 7 holes for the Rover crank  :y
(http://i4.photobucket.com/albums/y117/kenmacritchie/Image0463.jpg)
Post by: venom on 29 January 2011, 18:56:01
Well did quite good today and got the interior striped out and so far can only find a quite a big bit to weld up
And this is it but looks like some time ago it's had a bit done here before
(http://i4.photobucket.com/albums/y117/kenmacritchie/005-16.jpg)
And here
(http://i4.photobucket.com/albums/y117/kenmacritchie/003-11.jpg)
Without poking around to much the rest seems solid enough.
(http://i4.photobucket.com/albums/y117/kenmacritchie/001-14.jpg)
(http://i4.photobucket.com/albums/y117/kenmacritchie/002-11.jpg)
(http://i4.photobucket.com/albums/y117/kenmacritchie/004-13.jpg)
Looks like the rear screen rubber needs replacing as it's leaking.
(http://i4.photobucket.com/albums/y117/kenmacritchie/007-13.jpg)
(http://i4.photobucket.com/albums/y117/kenmacritchie/008-11.jpg)
