Chat Area => General Car Chat => Topic started by: Clarkey on 29 January 2011, 23:05:15
Title: Can front Foglights be retrofitted to an Insignia
Post by: Clarkey on 29 January 2011, 23:05:15
Is it possible to fit front foglights to an Insignia to original equipment spec? Have been informed it's not as there is no wiring in place if they were not factory fitted as the looms are bespoke to each vehicle. Have heard of it being done with an independent switch but would only consider doing it if genuine switch can be used.
James.
Title: Re: Can front Foglights be retrofitted to an Insignia
Post by: Lazydocker on 29 January 2011, 23:11:33
Anything is possible mate :y
Post by: tunnie on 29 January 2011, 23:13:06
James.
Can't see that being the case, not for fog lights. Everything is moving to single standard on the production line. Its much cheaper to produce a single set then just bolt on what ever spec is ordered.
Worth a look under the bumper for any tied up connectors?
Post by: andyc on 01 February 2011, 09:58:29
If the loom is there then you should be able to fit but you will need to use the OE parts as the car has a complete CanBus system and the BCM will need to be programed
Fog lamps are £64.00 each
Switch assy £39.65
Bumper Inserts £8.55 each
All + VAT, fitting and programing
but only if the loom is there
Cheers
Andy
Post by: Clarkey on 01 February 2011, 14:55:15
With enough time & money anything is indeed possible. Unfortunately I have a limited supply of both. :'(
Have been advised wires are not there. Will check for myself. Thanks for info.
James.
