Chat Area => General Car Chat => Topic started by: JamesV6CDX on 05 March 2011, 17:53:22
I've just spent a couple of hours changing the thermostat, on the 3.2...
Not a bad job to do really. The transfer pipe was a bit tough to get out of the stat housing, but slowly eased it out - didn't want to break it, as don't have a spare!
Other than that, job was no problem - the 'B' bolt is considerably easier to get to on the DBW engines - I did it with a ratchet and socket.
It's made a huge difference to the car too... the cabin heats up much quicker, and it no longer overcools on a run - so fuel economy will be a lot better too...
£25 and 2 hours well spent, I'd say!
Tomorrow's job, is to replace the cambet kit, water pump, auxiliary belt, and new aux belt pulley, all Genuine GM items.
And of course, a coolant flush, + 5 litres of red longlife coolant.
Would have done it all today while the plenum was off, but realised I left the camlock kit at my folks... durr!
Only other observation was camcover gaskets are ever so slightly weeping... so I'll be doing that over the next couple of weeks too, along with some new plugs, and an oil change.
Am enjoying getting my hands dirty once more :D :y
sounds a good start :y
Sounds like your enjoying being an Omega owner again. I shall look forward to seeing you and your new car at some point for a catch up :y
i just did mine on the bora, took me just over an hour (never done before) and 45 minutes of that was getting the bottom bloody bolt out!!
massive improvement though!, i've also just brimmed my tank so it'll be interesting to see what i get out of it
shall we start a sweep stake on how long you keep it? :P
he'll sell it when his insurance renewal's due ;D
A bit of practice on a DBW before you do mine :y :)
Alot less clutter on the DBW engines. 8-)
How come is it different on DBW cars? Cable tray and pas-reservoir are the same on both and they are the things making the b-bolt B :-? (not to say I had the most trouble with dropping the tools "somewhere", the 10mm spanner still being there)
