Chat Area => General Car Chat => Topic started by: TheBoy on 10 March 2011, 20:05:55
Title: LPG Gauge accuracy
Post by: TheBoy on 10 March 2011, 20:05:55
I know they are poor, but....
Having to re-setup mine after a retard moment. 90k growing.
Trouble is, the voltage is varying between a value, lets say 1.8v when tank half full to 3.22v.  This is all the time when in motion, spening most time on 3.22v
Surely the ECU reset wouldn't have buggered it?
Title: Re: LPG Gauge accuracy
Post by: Kevin Wood on 10 March 2011, 20:13:29
You'll probably find the ECU damps the signal quite heavily. Never looked at what mine does when in motion though.
Post by: TheBoy on 10 March 2011, 20:27:09
There is some damping, but the leds are still bouncing between 2 and 4 on all the time :(
Post by: Kevin Wood on 10 March 2011, 20:29:28
Ahh, something not right then.
Can you bundle Tunnie into the boot and ask him if the gauge on the tank does it too? ;D
Post by: TheBoy on 10 March 2011, 20:36:35
The gauge is stable - I can replicate it (to a lesser extent) when parked.
Post by: tunnie on 10 March 2011, 20:41:32
You put your gauge in a stupid place which is perfectly hidden while driving if i remember correctly?  ;D
I could easily do without the gauge to be honest, I always go on the trip.....
Post by: TheBoy on 10 March 2011, 20:44:18
I'm toying with putting Elite gauge in same place ;)
Post by: tunnie on 10 March 2011, 20:46:01
But you can't see it!? Well not from the drivers seat anyway!  :-?
Post by: TheBoy on 10 March 2011, 20:47:07
Perfect for not distracting at night ;)
Post by: tunnie on 10 March 2011, 20:50:08
Must be an age thing  ;D
Mine does not bother me at-all, its tucked well out of main 'standard' driving view.
If I had an Elite that I had to convert, I would seriously consider not fitting the gauge.
But I guess you have to, if you want to manually switch fuels  :(
Post by: feeutfo on 10 March 2011, 21:20:28
Gauge is fairly useless tbh. But if it's by the tm button it's the perfect place IMO. Easy access from engine bay, and only a slightbtilt of the head to see it. It's too bright for direct vision at night, and too dim in day time anyway.
All it really does is confirm LPG is on IMO.
Never had any lights flickering though.  :-?
Post by: Lazydocker on 10 March 2011, 21:26:24
But I don't think the system would even work without it as it's also the control switch ;) ;)
Oh... And it wouldn't pass an inspection with out it ::) ::)
Post by: Lazydocker on 10 March 2011, 21:29:10
Just a thought... Isn't yours one of the specified ones? Or was that Tunnies? :-/ :-/
Post by: tunnie on 10 March 2011, 21:30:34
Mine is specified at set amounts i think? Remember you setting them at Towcester?
Explains why I can get 70-90 miles on the red light!  ;D
Post by: Lazydocker on 10 March 2011, 21:33:09
Yeah, but you've rotated the tank a fraction since I set it up... Should have been about 60 miles on red, 70 ish on a run... That's what mine's at :y
Handy to know that it's consistently 60 miles after it comes on though :y
Post by: tunnie on 10 March 2011, 21:50:59
Yup. Although once I was very surprised I made it home, gauge on tank itself registered nothing, it was almost resting on the end stop, still got 75 miles out of it! - It did beep at me once, only had to force it back once.
Post by: TheBoy on 11 March 2011, 12:19:36
Not at the time, though I time AC now do a 90 growing, so it could match a Stag one (but the calibration is still pathetic).
My point seems to be that I reckon the gauage 'electronics' have gone haywire since resetting ECU. Can't see how though...
Post by: TheBoy on 11 March 2011, 12:21:05
I think thats a sign you've got the tank wrong.
On mine, one you have had a low pressure warning, thats your lot.  Maybe a couple of hundred yards more, but no more...
Post by: albitz on 11 March 2011, 12:41:32
Its supposed to beep when its about to run out  :question :o :-/
Post by: TheBoy on 11 March 2011, 12:43:50
No, it gives an error about low pressure, then switches to petrol.  The low pressure warning is because there is less than a fart in the tank.
Post by: albitz on 11 March 2011, 13:44:00
The only way of telling that mine has run out is the green light (on/off) blinks very fast.
Post by: TheBoy on 11 March 2011, 13:57:36
Ah, sorry, thought yours was Stag.  I suspect each system has its own method of alerting drivers to conditions.
The Stag bleeps 12 times when the pressure drops below whats set in the software. Bloody annoying - similar to those stupid, gay, pathetic, crappy Sony Xplode head units that do similar when you turn ign off.
Post by: albitz on 11 March 2011, 14:24:22
It is Stag - maybe someone has disconnected, or forgotten to connect the bleeper ? :-/
Post by: TheBoy on 11 March 2011, 14:27:21
Stag 300?
Post by: albitz on 11 March 2011, 14:33:40
break nose - ask lazytinker. ::) ;D ;D
Post by: Danny on 11 March 2011, 14:52:14
look at it this way, my mate just had his skyline remapped to the mid-400bhp area but his own mistake in preparations led to a complication that killed his engine
£5000+ cost for rebuild :(
i know its unrelated to LPG issues but still, just highlighting things could be so much worse!
Post by: Kevin Wood on 11 March 2011, 16:05:42
Yep. Agreed.
The pickup should be immersed in liquid until the end. If it starts drawing vapour from the tank while there's still a few litres of liquid, the engine will still run "miss daisy" fashion by drawing vapour up the line but it will switch to petrol as soon as you put any serious load on it.
Once mine has dropped to petrol it will switch back to LPG and idle grumpily for a few seconds but that's it. If it's doing a number of miles after dropping to petrol once then the pickup is not reaching the bottom of the tank IMHO, probably because the tank is at the wrong angle.
Post by: tunnie on 11 March 2011, 17:23:46
Yep. Agreed.
I can get about 15 miles ish after its beeped on a low tank, maybe 20
