Chat Area => General Car Chat => Topic started by: gstylebaby on 11 March 2011, 01:02:02
Hi all,
The diff on the estate makes for want of a better word whirring noise like the bearing is on its way out also there is oil on the drive shaft at the back wereit bolts to the diff. Am i right in think its the rear bearing and how easy are they to do. Any advice would be great peeps please.
I would summise, if its the prop shaft, that the pinion seal has failed, and your diff is in dire need of oil!
Any idea how hard the pinion seal is to replace :-/ :-/ ?????
Seek and ye shall find
http://www.omegaowners.com/forum/YaBB.pl?num=1157722402
Dead simple when 2Woody is on the scene ... and Kevin Woods has one in his boot .... IIRC it was done quicker then (and while) I did the ATF change ... :)
:y :y :y :y :y :y
Thanks rob, :y
Sounds like a right nightmare >:( >:(. Anyway if it needs doing i will have to have a go. :-/ :'(
:y :y :y :y :y :y
Not to bad if you have experience of these before. ;D ;D But i will have ago at anything just don't want to screw it up. ;D ;D
Hi all,
Can anyone tell me what parts i need to do this job only i have had a look at my e.p.c and shows lots of different seal's and bit. I want to make sure i have the parts before i do the job. I have found a place called vauxhall genuine parts and they are selling a pinion housing with seal is this what i need???? Please help peeps. :y
Anyone :-? :-?
O.k i'm hopeing to get on this on my days off but have still not sourced one yet. Do i need a vauxhall one or will one form europarts/andrew page be any good. Still not sure what this thing looks like so i'm flying blind as stated before the e.p.c shows a few different seals. Also do i have to get the diff oil from vauxhall or will halfords do one??
Any advice please.....
Have you priced a seal at the dealers yet?
As an aside, the guide referred to by Rob is splendid - well done to Mark, Matchless and Seprim. 8-) 8-) - great stuff.
No i've not priced the seal at the dealers mate. When i went to get my cam cover gaskets the other week the guy that works behind the parts counter....well shall we says hes abit of hard work. I would'ent mind but i used to work there but he started after i had left so thank god for small mercies. ;D ;D Plus the spares dept is so small now its mad it was massives before.
Seal from VX is only about 20 quid. Got AndyC to put one in the post for me.
There is a maintenance guide detailing the procedure. It's important to mark the original position of the pinion nut relative to the input shaft and tighten it to exactly the same position on refitting because this controls the preload on the bearing.
Thanks Kevin mite just see if andy c will do the same for me was that £20 all in (posted out to you) or mite go to a different vauxhall parts place. ;D ;D Bet we don't discount on trade club for these do we. :'( :'(
Great stuff G, I'll look forward to hearing how the job goes. 8-) :y
Nearly forgot what oil do i need anyone please???
Anyone?? :-? :-? I know it mite seem a daft question but i have never done anything with diff's so i don't want to go getting the wrong stuff and end up haveing to go back while i'm half way into the job.
If it's not an LSD then standard EP90 hypoid gear oil will do.
Thanks Kevin. Have p.m'ed Andyc a few days ago just waiting for him to get back to me. Was hoping to get this done this week. Oh well looks like its goning to be next week with any look. ;D
