Chat Area => General Car Chat => Topic started by: feeutfo on 26 April 2011, 11:04:19
Title: Exhaust care
Post by: feeutfo on 26 April 2011, 11:04:19
Given the oe system seems to be the best, but no longer available. I was wondering how best to try and pre long it's life, if at all. :-/
Main problem is the join, centre sections to back box. Moisture on the inside gets blown up the slope to the silencer and leaks out at the join rusting the outside as well. Least that's how I see it.  :-/
But what to do about it...?
Wondered about that heat insulation wadding they fit round headers to protect body work etc on special builds.
Wrap some of that round to keep the heat in and hopefully evaporate the moisture off quicker. But not sure if it's absorbent and might retain water doing more damage...?  :-/
Title: Re: Exhaust care
Post by: Lazydocker on 26 April 2011, 11:22:40
TBH, I wouldn't have thought the gasses were hot enough at that point in the exhaust :-/ :-/
You've got nothing to lose by trying it, except a few quids worth of heat bandage ::)
Best way to prolong exhaust life is not to do short journeys ;) ;)
Post by: SMD on 26 April 2011, 19:11:47
How old is your Elite 'Black'? I'm jealous of your original exhaust, I hope it doesn't last  ;D  :D
Post by: TheBoy on 26 April 2011, 19:33:57
I'm in the same boat as chrisgixer - my Elite is still on original exhaust, but I doubt for much longer...
Post by: r1 on 26 April 2011, 19:40:54
drill a hole in it
sounds daft but i just changed a system on a 407 and the rear silencer had a drain  hole in it.this was not a rusthole as the back box was fine never seen this before but must have passed mots okay
Post by: Dishevelled Den on 26 April 2011, 19:44:45
I put a Bosal system on my Desmond 2 years or so ago after the Vauxhall system rotted off.
The Bosal was never the same for quiteness. I considered replacing this when I put a new downpipe and cat on a few weeks ago but didn't bother - I should have, as it's now beginning to annoy the keek out of me.
The trouble is, I don't know what system I should use to give me the same level of refinement I had with the OE one.
Post by: Andy B on 26 April 2011, 19:56:35
I put a Bosal system on my Desmond 2 years or so ago after the Vauxhall system rotted off....
The Bosal system fitted to my Senator lasted just over 2 yrs ie just till the guarantee ran out. That was when I built my own stainless system.  ;)
You don't want a s/s Jetex then. It's nothing like in the same league as a full on 6" dia Max Power system, but noisier than OE.
Post by: Dishevelled Den on 26 April 2011, 20:37:33
I'm not sure what to do Andy.  The system from the cat back appears to be intact but there is a terrible flat rasp from the exhaust note - although I could hear something rattling inside the back box after wiggling it about a bit when I was underneath the car taking the back discs off last week.
I like a quiet exhaust and only wish the original Vauxhall one was still available.
Post by: omegod on 26 April 2011, 20:44:20
Mine had a Bosal on when I bought it and I eventually got bored of the drone at 60-70 so I was lucky to find a stainless Irmscher backbox which turned out to be quieter all round(except over 4000RPM when it makes a gorgeous noise) The old one was full of rusty mush when it came off!
My centre box has a blow now and like yourself I don't know which way to go.
Post by: feeutfo on 26 April 2011, 20:50:57
03 with 60k on it,  8-)   thanks to Josh.  :y
I reckon there's a a year, maybe two at a push, left in the oe system.
Post by: feeutfo on 26 April 2011, 20:54:01
drill a hole in it
That's something I have wondered about ...
Would save the join area, but some rust would form round the hole, but then the join has 4 holes round it, where the slots are, and that lasted long enough....    :-/
Post by: feeutfo on 26 April 2011, 21:01:46
Eternal seems the only cost effective option, but I'd be disappointed with the quality, if not the price. Note quality is better than the current crop of tc exhausts(similar to, if not made by,bosal) but still priced similar to the oe system less 20%. which still seems steep to me...?
Post by: TheBoy on 26 April 2011, 21:32:04
eternal is about £130 for all 3 parts, deliverd  :-/
Post by: feeutfo on 26 April 2011, 21:43:31
Current crop tc exhaust was £311. Now less 20%. So £248 ...?
Post by: VXL V6 on 26 April 2011, 22:16:56
Wouldn't it be good if someone with excellent metalworking skills and access to good quality materials could build us all custom systems to the same level / better level than the Original GM systems?
Sassanach!!!!! Where are you?
Post by: tidla on 27 April 2011, 00:09:01
i put a walker 3yr g tee rear box and some 2yr centres. noise level is spot on and sounds good when you want it too.
did do a vid of the noise. will have to dig about.
Post by: doug4293 on 27 April 2011, 04:10:53
i have seen back boxes with a small drain hole in them also as standard, good idea just to drill a small hole in it
Post by: Kevin Wood on 27 April 2011, 11:06:54
I would say an Eternal system might be worth a punt. It's a little noisier than OEM but not in an irritating raspy way .. on a V6 , at any rate. Not too great an outlay to try one either. :-/
The problem with drilling drain holes is that drain holes drilled during manufacture would have been done before the exhaust was galvanised. I suspect drilling one afterwards will provide a nice starting point for the tin worm to get a hold.
Post by: TheBoy on 27 April 2011, 11:46:50
I have eternal on the MV6. Yes, noisier than the original OE's, but not noisy like the usual junk the likes of ShitFit and ATS through on.  I believe the external ones are just KT ones?
Certainly doesn't have that annoying, tiring drone that many patterns have when cruising...
Post by: Dishevelled Den on 27 April 2011, 12:21:21
Thanks to both TB and Kevin :y
I'll look at Eternal's site.
Post by: kevinminton on 27 April 2011, 13:39:44
My OE system finally became intolerable in January at 100,000 miles & 7 years. Mind you, I had patched it up with a pilchard tin for the MOT in 2010.
Got a secondhand OE system off ebay for £50. Went straight on and looks like it will be good for 18 months at least. That seems like good value to me.
Post by: Bent valve on 27 April 2011, 20:54:42
Exhaust systems are made from pre- aluminised(not galvanised) steel, and any welding, fabrication or drilling takes place after the raw material has been aluminised.
Whenever I fit a new exhaust to my own vehicle I paint all the welds, including the machine weld that runs the length of the tube with a zinc rich paint such as Galvafroid.
I also coat the joints and clamps after fitting.
IMHO it would be a good idea to coat the welds on the inside of the tubes at the rear of the middle section as well prior to fitting if you want to really maximise the life of the system.
