Chat Area => General Car Chat => Topic started by: TheBoy on 13 May 2011, 17:53:39
Title: Change cambelt now or nearer due date
Post by: TheBoy on 13 May 2011, 17:53:39
Cambelt due in 15k or by sep
Change now or in summer
Title: Re: Change cambelt now or nearer due date
Post by: Del Boy on 13 May 2011, 17:54:20
May as well do it now, get it out of the way  :y
Post by: plym ian on 13 May 2011, 18:05:27
do it now. had a mondeo once and was going to wait till it needed doing but then it snapped gutted  :(
Post by: Jimbob on 13 May 2011, 18:07:08
for the sake of 4 months, do it now.
Can you guarantee they did the tensioners when it was last done?
suprised youve driven it this long  :o
Post by: Lazydocker on 13 May 2011, 18:07:12
Leave it a bit longer... Lakes & Newent before/when it's due ;) ;) :y :y
Post by: 51M0N on 13 May 2011, 18:08:56
Mine was done 7 years ago but has only covered 35k, I think i should do mine too
Post by: Lazydocker on 13 May 2011, 18:12:48
Of course they did... He's got a full Vx service history :-X ::)
But you make a fair point... With the other, unknown problem, perhaps changing it would be more sensible
Post by: Andy B on 13 May 2011, 18:14:15
Cambelt due in 15k or  .......
You've got till the end of Aug or 14 999 miles ...... you've got ages yet!!  ::) ::) ::)
Post by: cem_devecioglu on 13 May 2011, 18:43:34
change now and after 1 month check the tension imo :)
Post by: feeutfo on 13 May 2011, 19:02:17
As the kit is sitting in the garage, fit it, it's no good sat on the shelf looking at you crying, so to speak, over a load of bent valves.
Get it on the car, ESP given recent events and a history you've questioned yourself.
Mine however, is fine, obviously.  8-)
If only I could be sure about that noise.... :D
Post by: hercules on 13 May 2011, 20:14:26
unwrap the tree branches and put a proper belt on :y
Post by: Darth Loo-knee on 13 May 2011, 20:28:38
Personally I don't even let my own run up to the 40,000 miles or 4 years seen to many go at that time :-?
Get it done now JAMMIE :y
Post by: mrgreen on 13 May 2011, 20:35:45
i say change now as surely in summer there's better things to be doing than changing a cambelt!
Post by: Shimmy on 13 May 2011, 20:39:55
I voted yes from the luxury of my arm chair on the internet behind a monitor.
:D ;D
Post by: Grrrrrr on 13 May 2011, 20:57:22
I'd do yours as a matter of urgency! 7 years sounds a long while and most people on here wouldn't dream of leaving it past 40k.
Post by: hoofing it on 13 May 2011, 21:20:57
It won't matter when you change it. It will still piss down with rain an hour into replacing it ;D :D
Post by: CaptainZok on 13 May 2011, 21:40:36
Your cambelt fitter will be at the lakes. ;D
Post by: Vamps on 13 May 2011, 21:46:13
Or 4 years, so 3 years overdue... :( :( :(
Post by: Elite Pete on 13 May 2011, 23:16:54
Strewth, thats 3 years over due, it will end in tears :(
Post by: henryd on 14 May 2011, 00:00:10
get it done and out of the way TB,plus you don't know if a muppet did the last change  :D ;D
Post by: TheBoy on 14 May 2011, 10:20:54
It can rain all it likes an hour after I start the work - I will be long finished within that time ;)
//Edit: Assuming the previous monkey timed it properly, and I don't have to mess around getting the locks in properly
Post by: TheBoy on 14 May 2011, 10:26:06
My reasons for leaving until the summer is that I intend to keep the car a while, so likely will be putting another belt on at some point.  I'd rather it became due in the summer again, rather than having to change it in our normally wet Spring (not undercover facilities here.
I can't change it at Lakes or Newent, as its likely that Mrs TB will want the car so the OOF Widows can try and lose Mrs AutoAddict in a shopping centre again go out to play ;D
Post by: Martin_1962 on 14 May 2011, 10:41:07
I have done 22,000 on mine, got a potential leaking cam seal (if not it is oil pressure sensor) not cam covers.
If I do it this summer - would it be worth fitting a new belt?
Post by: albitz on 14 May 2011, 10:45:09
Mines now 500 miles overdue. Will be done tomorrow. ::)
Post by: 51M0N on 14 May 2011, 11:06:28
Its getting done in the next few weeks. will i need to change water pump too?
Post by: albitz on 14 May 2011, 11:12:28
The conventional wisdom says yes, although Im not entirely convinced. Having said that, I bought what appears to be a decent quality one at a decent price, so was planning to change it with the belt and tensioners tomorrow - if Parcelfarce can be arsed to deliver it.
Post by: 51M0N on 14 May 2011, 11:13:11
I thought so too for the sake of £23
Post by: TheBoy on 14 May 2011, 11:17:46
Any chance its leaked onto belt? If so, yes
Post by: albitz on 14 May 2011, 11:20:12
You doing it yourself/garage/OOF mechanic....?
Post by: Olympia5776 on 14 May 2011, 11:27:19
I'll second that ..... :y
" never put off 'till tomorrow what you can do today.... "
Post by: 51M0N on 14 May 2011, 11:36:29
I'm pretty competent and I did my old vectra one before and that was a nightmare. I have all the locking tools too so once payday comes ill get the parts. assuming the last person timed it right should be no problem as its right in front of me.
Post by: albitz on 14 May 2011, 11:44:41
Get the OOF DVD it will be the best few quid (£4 ?) you ever spend. :y
Post by: TheBoy on 14 May 2011, 12:16:29
£3 delivered.
Well worth it, even if you do have to look at Marks DTM Calib's knobbly knees ;D
Post by: jb on 14 May 2011, 21:48:55
My experience is that its more to do with hours running than yrs/mileage.I have an x reg mv6,ex met police ,all motorway miles,changed original belt kit at 92k and it was A1.Also until last sept had an ex tvp r reg mv6,changed original belt kit also at 92k with a Gates Kit - motorway miles since 2003 now on 172k and running strong.........
I think 4 yrs 4o k may be a little conservative but its an individual judgement...........
Post by: 51M0N on 14 May 2011, 21:58:50
I agree with the above to an extent, its also boils down to pot luck too lol.
