Chat Area => General Car Chat => Topic started by: albitz on 19 May 2011, 22:51:53
Title: Downloading Stag softwear
Post by: albitz on 19 May 2011, 22:51:53
My ECU is a stag 300-6. I dont see mention of this on the website. It appears to be premium/plus etc. which is reffered to.
Anyone know what I should be looking at/for ? :-/
Tia.
Title: Re: Downloading Stag softwear
Post by: albitz on 19 May 2011, 22:56:45
I think Ive found it now. Should come under plus by the look of it.
Post by: Kevin Wood on 20 May 2011, 00:04:34
Sounds like a vanilla Stag300 to me, so the plus software won't work. You need ACGasSynchro software 1_14_1_0.
http://www.ac.com.pl/public/pubonline/cms/files/Programy-i-instrukcje-obslugi/pl/Stag%20200%20300/SetupAcGasSynchro-1_14_1_0.exe
This should update the firmware when you connect to the ECU if it's required.
You MAY lose all your calibration and setup, and, helpfully, saving and loading the setup to the PC doesn't work with this ECU IME. Don't update unless you are in a position to map the system from scratch.
Stag300 firmware hasn't changed in a long time (since I converted 2.5 years ago IIRC) and, if it's not broke...
Post by: Lazydocker on 20 May 2011, 00:16:51
Yep... That's the version you want :y
As Kevin says, if it ain't broke, don't fiddle! I'm fairly sure I've done the firmware update on it for you already. If you are going to play, I'd recommend taking some screen shots of the settings so you can put them back ;)
I have your lead but I think I'm supposed to be picking something up from you so I can have a look then if you like?
Post by: albitz on 20 May 2011, 00:41:52
I think I will leave well alone then.
What are you supposed to be picking up Paul ? I havent a clue tbh. :-/
Post by: Lazydocker on 20 May 2011, 01:13:06
Scrub that... Change of plan ::) I should be going to see John next week as he's going to lend a hand to do a couple of bits :y Fancy meeting up and I'll talk you through the Stag Software?
Post by: albitz on 20 May 2011, 01:18:44
Thats possible. I will be returning his locking kit soon anyway, so could try and tie it in. :y
Post by: Lazydocker on 20 May 2011, 01:27:41
Obviously my offer still stands, if you get stuck I'll happily nip down and give some moral support ;)
I'll let you know what day I'll be going to Johns
Post by: albitz on 20 May 2011, 06:29:50
You MAY lose all your calibration and setup, and, helpfully, saving and loading the setup to the PC doesn't work with this ECU IME. Don't update unless you are in a position to map the system from scratch.Stag300 firmware hasn't changed in a long time (since I converted 2.5 years ago IIRC) and, if it's not broke...
Umm - anyone want to buy a brand new lead ?? ::) ....its obviously going to be break all use to me. ;)
Post by: Lazydocker on 20 May 2011, 20:48:33
You'll use it..... Very occasionally ::) ::)
If we don't meet up during the week I'll stick it in the post :y :y
