Chat Area => General Car Chat => Topic started by: albitz on 22 June 2011, 00:49:45
Title: Camshaft identification
Post by: albitz on 22 June 2011, 00:49:45
3.0 cams are G+A ? but what letters denote 3.2 cams ?
I may (hopefully) be selling mine soon, and would like to be sure I can identify the inlet/exhaust and their markings beforehand to assist a buyer with fitting.
Title: Re: Camshaft identification
Post by: joff on 22 June 2011, 00:59:59
lable them before you take them off then you will know which is which ;) ;)
Post by: albitz on 22 June 2011, 01:11:43
Should have done. ::) ;D
Post by: joff on 22 June 2011, 01:33:22
I will have a look at the 2.6 cam's i have removed (labled first) when i get up off of nights and see what they have on them and let you know albs, what have you got on the 3.2's anything at all. :-/ :y
Post by: albitz on 22 June 2011, 11:31:18
Thanks Joff. there are some markings on them. I will make a note of them later. :y
Post by: albitz on 22 June 2011, 21:44:04
All four are marked - R90400057
Three of them are marked - GC29
The fourth is marked - GC26
Im slightly confused. :-/
Post by: tunnie on 22 June 2011, 21:53:32
Has it had any work done on it? Is there any history? 3.0 cams, the G's are inlets, A is exhaust, if R is exhaust on 3.2 then someones c0cked up refitting them  ;D
Post by: aaronjb on 22 June 2011, 21:55:42
I know I'm doing a terrible thing here linking elsewhere but, does this help at all, Albs?
http://www.migweb.co.uk/forums/engines-transmission/238050-another-v6-cam-question.html#post2491881
(Reply number 8 there which implies those numbers are all 'blanks' numbers and you're looking for a different number ..)
Post by: albitz on 22 June 2011, 22:09:24
No history to speak off, but the engine gave the distinct impression that it hadnt been apart at any time. ;)
Post by: Lazydocker on 22 June 2011, 22:12:39
From what I saw of it I'm not convinced the oil filter or cap had ever been off :-X :-X :o :o
Post by: albitz on 22 June 2011, 22:23:10
You did a very very good thing Aaron - sorted now. :y
I have two G cams - inlet I believe (same as on 3.0)
And two J cams - exhaust I believe (only from 3.2 engine, I think) :y
Post by: aaronjb on 22 June 2011, 22:28:23
Glad you found the marks you needed :)
